XJ12 Rb25DET Conversion
What's going on everyone, my R34 was written off not that long ago and in my search for a rolling shell I have come across a rather clean Series II XJ12 shell. I'm looking to engine swap my RB25DET making roughly 500rwhp (370rwkws) on 21PSI of boost & E85 into this shell. Does anyone have any experience with this kind of build?
I've poured close to 15k into my engine on the R34 and as much as I love them, it's time to make a change in what I am doing, however would like to get an idea as to what I am getting myself into before I dive straight in. The mechanics side of things is the easy part, My main concerns are about how the motor will line up with the rest of the shell and if the shell will comfortably hold that much power & more. Obvious suspension work will need to be done as the shell is completely stock.
Where's the sump? I'm not familiar with your RB but as long as it rear sump it will just need basic fab to set in there. I've got a SBC with similar HP and the rear suspension mods to handle that amount of power are extensive. There is no upper control arm on the rear spindle and it move around under power. The hit from a turbo will only make that worse. There is also limits to rear tire size with out metal work.
Also the RB is a Rev'r not ideal for a heavy XJ. Plan on doing lots of weight management. I'm working on getting my XJ down to 3600 Lbs this week, I'm at 3700 and the mods are extensive.
Look up my 2015 and 2017 coupe projects. You will see the mods necessary to prevent these car from twisting under power.
My first XJ project with 400 flywheel HP and no chassis mods would auto change lanes on the highway under power.
ronbros (03-04-2019)
Satakewawa
02-06-2022 06:41 PM
XJsc-guy
08-25-2013 05:56 AM
XJsc-guy
08-10-2013 11:45 PM
