XJ6 for $500
XJ6 for $500
Newbee dreaming the dream. Local has an '82 XJ6 for $500 with $300 in back fees. 110k miles, daily driver until last year when his mechanic "dialed in" his Jag before going out of business. Said the mechanic adjusted the mass air flow and the XJ6 started running very ruff. Engine would race then drag. Has been parked for a year. Garaged most of its life and paint touched up recently.
What do you think? Love to finally get my Jag but hate to buy a massive repair issue.
Well... It depends on how you look at it....
For $500, you could scrap it and get your money back if it turned out to be a lemon...
But, I also notice you are from CA... And with your state's inspections, you may never get it on the road.
If you want one to jump into and drive right now, I'd likely pass on it. If you enjoy tinkering on the car and wouldn't be dependant on it, Go for it..
I've bought a bunch of them that only had "this or that" wrong with them, and it ususally turns out to be quite a bit more than the PO acknowledged.
These cars don't like to sit idle, and seem to break down just as much from sitting as from driving... If the problem is indeed a AFM, Used ones can be had for about $35... Pop the old one out, put the new one in, and you're good to go.
Personally my daily driver cost me $300. I trailed it home, but a distributor cap on it, and it fired up on three year old gas. It's turned out to be excellent in every way. Of course having a parts business helps me, if something breaks I just go to the shelf and replace it, no worries...
Cheers,
David
www. EverydayXJ.com
Cheers,
David
www. EverydayXJ.com
Received 2,632 Likes
Newbee dreaming the dream. Local has an '82 XJ6 for $500 with $300 in back fees. 110k miles, daily driver until last year when his mechanic "dialed in" his Jag before going out of business. Said the mechanic adjusted the mass air flow and the XJ6 started running very ruff. Engine would race then drag. Has been parked for a year....
Thanks for the input - This has been sitting for a year and hasn't been registered for a year. Hmmm. Looks like it wouldn't pass smog, could be AFM. Sounds like other issues probably copped up over the last year.
Running with good paint - worth maybe $2500 right? Could be better to just spend the $2500 on a running rig.
X308XJR
05-20-2019 06:50 PM
FS[MidAtlantic]: 1997 XJ6 VDP $3,900 - Very RARE Anthracite on Warm Charcoal
42Ajd
09-26-2015 07:04 PM
