XJ6 1978 S2 ride heigh problem
Dave,
I cannot comment on your particular case, but I can tell you what has happened so far with my series 1 rebuild. My car had had new springs fitted prior to the rebuild and sat around the 626mm mark - a bit high, So when I fitted all new rubbers, bushes etc and added 1/8 spacers under the spring pans, I though it would sit about right. - close to the 611mm. Not so. The engine was out at the time of front suspension rebuild (same springs used) and when re-fitted the ride height was way up around the 680mm mark! Tried to jump on the front end to settle the springs without success. As yet have not fired the engine and driven the car, but am hopeful that after a few applications of the brake the front will start to settle.
So my advice is to wait before you make any further adjustments. I am hopeful my front end will settle correctly and yours will too.
John
Dave,
John
Dave
When you replace the front springs and Control arm (Wishbone) bushings, the bushings must be preloaded before the final tightening to torque specs.
Failure to preload will cause the front of the car to sit higher than normal and place stress on the newly installed CA bushings causing premature bushing failure.
yachtmanbuttson (04-19-2022)
Dave
Following up on this thread. As indicated in a previous post, I had overhauled every element in the front suspension and was concerned when the ride height after installation of the engine sat very high at 680mm. Once all the other stuff in the engine bay + fluids were added, and after a drive around the property, it still seemed high at 635mm. But I had yet to install the bonnet and bumper.
I can now report that with everything installed and having driven the car on road for awhile, the ride height is 612mm right and 619mm left with tanks 1/4 full. I am pretty happy with this. I may try to adjust the left down a fraction by grinding the springs down a bit more. The point of the post is that the ride height can only be checked once every part is back in place and the car has been driven to settle the bushes properly.
The following 3 users liked this post by The Mekon:
Received 2,399 Likes
Somewhere I read that the measure point is at the center of the outboard head light.
My car was low when DOHC powered I like the look…
When the LT1 went in, it rose a bit. I measured and found it now at spec, whatever that was. I got used to it.
A good way to lower this suspension, so I've read, is to add shims between the spring pad and the lower wish bone..
Carl
Carl
#31
AccidentlyInLove
03-22-2017 12:46 AM
