Xj6 front suspension unit/subframe bushing
I recently purchased a 1983 XJ6 and going through many of the old/original parts and swapping them out to prepare for a 1000 mile road rally around Lake Michigan in the spring. I have a LONG list... but one of those items is to replace the front suspension bushings, which have seen much better days.
My question... can I replace these front suspension unit bushing, while on car car, relatively simply?
The service manual leads me to believe I can do this... and simply need to:
Thanks in advance! -Nick
- set the car on jack stands at the lifting points (already in that position)
- support the suspension unit with a floor jack
- loosen the retaining nut for the bolt that connects the bushing to the frame
- loosen the bolt that tightens the strap-like assembly around the bushing to the suspension unit
- slightly lower the jack
- tap the bushing out
- retain the sleeve and install into new bushing
- push the bushing and sleeve back on to the mounting bolt
- tighten the bolt that tightens the strap-like assembly around the bushing to the suspension unit
- reattach the nut (and complementary washers, etc.) to the mounting bolt.
- REPEAT on other side.
I think you mean the large subframe bushes that attach the front subframe to the front of the chassis under the radiator? The ones with 6 holes in the rubber, and a massive huge nut and bolt going through the middle?
If so, these are not suspension bushes (which are to attach the wishbones - control arms to you - to the subframe). The ones you describe sound like the ones that insulate the front of the subframe from the body monocoque.
If this is indeed what you mean, your method will be fine.
BUT, you MUST use genuine Metalastik brand to replace the old ones.
The following 2 users liked this post by Greg in France:
Grant Francis (01-30-2021),
Naber (01-29-2021)
The following 2 users liked this post by Fraser Mitchell:
Naber (01-29-2021)
Received 9,280 Likes
I found a chart for relative hardness of Poly in various applications:
https://www.eeuroparts.com/blog/how-...poly-bushings/
Here would be a Wonderful niche item especially for Classic Jaguar Enthusiasts; To set up a small backyard factory to manufacture Long Lasting suspension bushings made of Poly about as hard as the original Metalastik bushings.
Best of both worlds! Soft and resilient as Metalastic, long lasting like Poly.
Now I just need the backing...........
The following 2 users liked this post by LnrB:
Greg in France (01-29-2021)
Good Luck finding those! Certainly there are NONE left on the planet for Lower Wishbones.
https://www.sngbarratt.com/English/#...e-a2df67e3acb0
Mind you, it is over three times the price of the repro items, but as you will only replace these once in your lifetime, better to spend the money, I say !
Also they have the rear V-mounts
https://www.sngbarratt.com/English/#...7-629610719ac2
Cost nearly twice the repros, but again, you'll be dead before you have to replace another one.
The following 3 users liked this post by Fraser Mitchell:
Naber (01-30-2021)
i wish I could report the same success. Despite heat, I could not get this thing to break free. It’s a silly price, but found them on Moss for $30 and just bit the bullet and ordered new.
Received 10,906 Likes
Item #10 in this illustration. Old number C30314. New number MHC2370AA
https://parts.jaguarlandroverclassic.../brand/jaguar/
Sorry I'm late, my presence was required elsewhere for a couple days.
Lower Wishbone bushings: C8673
And, rather than hijacking this thread, which I had No intention of doing, I'll start my own on this subject.
Greg in France (02-07-2021)
LnrB (02-07-2021)
1983turbojaguarxj6
05-23-2018 04:30 PM
