Xj6 ignit in key and barrel unit
Old 01-08-2018, 05:49 PM
Francis Panton's Avatar
Default Xj6 ignit in key and barrel unit
Hi guys. On the XJ6 ignition unit. What and where does the purple and black wire go to. It possibly looks like a earth.
does this need to be earthed to start the car?
problem is that my key and barrel are buggered and I need to move the car. I can remove the ignition easily enough but need to start her. Is this wire a earth? XJ6 1974 SERIES 2
Old 01-08-2018, 08:26 PM
Received 6,327 Likes on 4,370 Posts
Hi Francis, I must have missed your intro thread when you joined. I have added you to the NZ Roll Call thread.
https://www.jaguarforums.com/forum/n...8/#post1821965
As for the purple/ black wire you don't need it. You have another one on your steering column for the horn. I replaced my ignition switch last year and after much research discovered the purple/black wire from the ignition switch has nothing to do with the horn but is a separate circuit for US market cars, it is for a warning buzzer we don't have on Australian or NZ delivered cars.
I found it in a wiring diagram for US specs. It seems the same harness is on all cars but un needed wires are not used.
Edit: I will try to find that diagram tonight and post it, for peace of mind.
Old 01-08-2018, 08:36 PM
You should be able to start the car without the key lock attached. In the back part of the switch (the harness that attaches to the back of the lock) you can turn the part in the inside with a screw driver and the car should start....mine did.
The barrel and lock are there just to stop other people turning your ignition and driving off with your car.
Old 01-09-2018, 07:16 AM
Old 01-09-2018, 07:36 AM
JagCad's Avatar
Received 2,399 Likes on 1,880 Posts
Yup.
When I swapped out my overly worn ignition switch for a NOS unit I found that part. A PO had disconnected the alarm buzzer. The alarm is not to leave the key on!!! I reconnected it. The NOS unit from David Boger at everydayxj fixed a lot of oddities.
But, to jump start an XJ. All you need is to release the pin that lacks the steering. Barrel out will do just that. Then, a jump from one of the cowl posts to coil +. And another jump to the R/w from the start relay. Or just + from a cowl post direct to the solenoid on the starter.
Carl
Old 01-10-2018, 07:05 PM
excellent. Thank you for that. A replacement key barrel is very hard to find. Nothing available here in NZ
Old 01-10-2018, 07:07 PM
excellent thankyou for that. Cheers
Old 01-11-2018, 03:08 AM
john_cook12
06-13-2018 08:31 AM
Jaguar Forums Editor
Jaguar Press release
07-31-2017 03:18 AM
07-25-2017 08:38 AM
john_cook12
02-10-2013 10:47 PM
Sean B
03-26-2010 09:56 AM
Quick Reply: Xj6 ignit in key and barrel unit
