Xj6 s.3 battery draining
Was having trouble starting. Thought maybe starter.
Battery died yesterday. Kindly old neighbor tried to jump start, to no avail.
Thankfully, he has charger. Hooked up for an hour, and then started right up.
He suggested electrical system draining.
So, for now, unhook battery when parked, then attach to drive. This works, but not a long term solution.
Suggestions?
Suggestions?
Its also possible that your battery has reached its use by date, do you know how old it is? You can put a multimeter in series with the battery (car static and everything turned off) if you see more than a couple hundred milliamps then the battery drain story is worth pursuing(really a guess as I dont know what in your car, assuming a radio memory and clock would be all thats drawing)
Battery drain can come from a variety of sources. Look for obvious things first , make sure all you interior lights are actually turning off, check the boot light turns off when you operate its switch by hand.
If you do tinker electrically you can trace sources of drain by measuring at fuse points, this is made more interesting in our cars as fusing is somewhat distributed. There are numerous Youtube videos on this topic, some of the better explanations are on the ETCG or Briansmobile channels.
If you arent electrically inclined , I'd be straight off to the auto electrician.
Other more knowledgable people may be able to suggest common causes.
the battery could be dying, not holding a charge.
if the battery is good and fullly charged, then check each door warning light by pressing the door jamb switch on each door jamb.
there is a light at the rear part of each door, you can see it when you open the doors. Though they normally come on when the headlights switch is in any of its ON positions, sometimes they stick in the ON mode.
if none of that is causing the problem, look for any added switch that a previous owner might have installed.
Sometimes the third brake light - a worthless invention - seems to be staying on, even when car is shut off.
Possible to disconnect?
Thx.
Received 10,920 Likes
Yes, it can be disconnected....although I can't remember the most convenient place to do so. Perhaps right at the lamp itself.
What year is your car? Is this an add-on brake light or factory installed? Factory installations began in '86 as I recall...and the circuit is powered-up only with the key 'on'.
Third brake light:
I'm thinking you have some sort of back-feed situation going on. Mulling required; not sure where to begin....but faulty grounds can have extremely strange results.
Any sign of weird wiring hacks by previous owners or mechanics?
Someone mentioned the door lights staying on; worth checking. If that's happening AND your power antenna isn't working, check the power antenna fuse. If the fuse is blown a back-feed will occur and power-up the door lights. Jaguar was aware of this an issued a tech bulletin to address the issue by adding a diode into the circuit. I can't remember if this fix was incorporated into production or if it was always an after-the-fact thing.
Third brake light:
Battery was toast. Thx
to disconnect the third brake lamp:
press under the cover, there are two push-up Tabs, and carefully pull the cover off, same procedure to replace the GE #194 bulbs, i.e., remove the cover.
you will see on the right side of the lamp a grey connector with two thin wires.
carefully pry it off and that's it.
Doug (12-10-2017)
Received 2,399 Likes
Ideas:
1. I like the idea of a top high mount third light. My 83 does not have one. But, I am not going to "monkey" with it's electrics.
If indeed, it is powered only with the ignition switch in "run" and it is on with the switch in "off", I see the switch itself as a cause. They wear out. Age and heavy key rings. They are not that robust. Been there done that.
2. Just remove the bulbs. leave the wires intact. less chance of odd results.
Caveat. I don't know if the lack of bulbs will trigger the bulb failure lamp on the fascia.
A review of the S57 schematic should tell if it is.
All folks with old cars should have battery chargers !!! I am no longer
a fan of jump boxes or cables. But, at times, it just has to be....
Carl
Carl
Carl, it is very easy to update your car to a Top Center Mount stop lamp:
there are only two wires, one is a Ground that can be connected anywhere to the body.
the other wire is 12v power. I connected mine to the tail lamp Stop light bulb wire, running the wire to the trunk through a hole that is already there with a rubber grommet.
No issues, zero, nada, works perfect. The Bulb Module continues as normal.
To stick the lamp to the glass, I used 3M double stick tape. Just get it centered and as close to the bottom as possible, but leaving space to get your hand under to remove the cover.
I would have preferred it at the top of the glass, BUT, it interferes with the rear view mirror view.
The following 2 users liked this post by Jose:
Doug (09-30-2023),
yachtmanbuttson (09-29-2023)
Received 1,067 Likes
Some years ago, I had a similar problem in my S3 Xj6.
It was leaking about 1 + amps and would flatten the battery in a day or so.
I found the leak by putting a multimeter between the battery and the main battery lead.
Turned out to be a "leaky" diode in the alternator. The alternator still seemed to work OK i.e., produced charge and no warning light.
A new diode plate fixed the problem.
Anyone is free to do as they please, of course, but tracking a 25ma draw is time that might be better spent elsewhere on an oldie Jag ![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
That amount of draw does not represent a problem by industry standards.
From this website; there are others expressing the same.
https://continentalbattery.com/blog/...g%20its%20life.
“Typically, the normal amount of parasitic draw is between 50 and 85 milliamps in newer cars and less than 50 milliamps for older cars.
None of my older Jaguars (Mk1, Mk2 and S3 Xj6) are daily drivers. More likely once a month.
Even that miniscule 25 milliamps (Ma) that Doug mentioned amounts to a serious drain on a battery over a period of 30 days X 24 hours a day = 720 hours.
720 hours X .025 Ma =18amp hours which amounts to a fair loss in capacity. Take that up to double with 50 Ma and 36-amp hours and you are definitely getting close to a flat battery.
Consequently, I have fitted quick disconnect battery devices to these cars so there is no parasitic drain on the batteries.
With a regular top up with a battery charger I am getting a typically 5 year battery life and a good start every time
yachtmanbuttson (10-01-2023)
