XJ6 S1 pulls left under acceleration
Old 06-07-2011, 04:22 AM
JBee's Avatar
Default XJ6 S1 pulls left under acceleration
Hi all,
as the title says, my 350 Chevy-powered Series 1 XJ6 pulls left under acceleration.
I THINK the problem is soft front suspension assembly mounts, the V-shaped ones above the chassis rails in the front end. I reckon they're allowing the front suspension assembly to twist because of the engine's torque.
Has anyone else had this problem?
Are you able to tell me what fixed the problem for you?
I've had a decent search of these forums but couldn't find anything that related to this problem.
Thanks,
Old 06-07-2011, 09:18 PM
JameyXJ6's Avatar
I'd suggest checking your rear suspension too. If the bushings are bad in the trailing arms you may find the torque is pulling one wheel forward.
Old 06-07-2011, 11:56 PM
JBee's Avatar
Thanks for replying.
I replaced both large and small bushes in both of the rear trailing arms when getting the car on the road. Damn
Old 06-08-2011, 09:08 AM
Received 8,119 Likes on 4,901 Posts
It's the outer lower hub fulcrum bearings that cause the 'rear wheel steering'. I just replaced some on a 1993 XJ-S that would torque steer under hard accel or sudden decell. The bearings are 03062/03162.
bob gauff
JBee (06-12-2011)
Old 06-12-2011, 08:36 PM
JBee's Avatar
Thanks Bob, I hadn't replaced the fulcrum bearings, thought they were OK. Will check that out.
Johnken
04-08-2018 10:21 AM
King Charles
10-16-2015 01:25 AM
mat32essex
10-03-2015 04:12 PM
baskervillema
10-01-2015 01:59 AM
Quick Reply: XJ6 S1 pulls left under acceleration
