XJ6 S3 Brake Lights Out/Wires from brake switch
Brake lights won’t work, fuse is ok, other tail lamps work. Someone has previously “re wired” stuff. From brake switch there is a solid green wire and green w purple stripe, both continue on as installed by factory. Solid green wire goes through aftermarket junction box that also has a red and a brown wire joined together but cut off just outside junction. Random brown and red wires were bundled in fuse box area, had clips to connect to glass fuses and have inline modern fuses. They were not connected to anything.
Welcome to the forums wjhickman,
I've moved your question from General Tech Help to XJ6 & XJ12 Series I, II & III forum. This is the place to post technical questions about your model.
Received 2,399 Likes
I was there. I bodged a fix.. Not good. Later found the real culprit. The ignition switch.
The left under scuttle fuse rack is powered from it!! Undid bodge., back to factory. All is well.
There are two brake switched operated by the pedal!!!! Opposite function!! Different tasks!!
1. Closed til pedal applied. Disables Cruise control!!
2. Open til pedal applied. Powers brake lights!!
3. I prefer solder and shrink tubing to make splices. Some say crimped connectors
are best !!!
Carl
are best !!!
Carl
RudyF6 (05-01-2019)
Received 9,462 Likes
Greg in France (12-24-2019)
JMSR, I might be out of sync with your findings but: brake light relay pulled, do lights go out?
If yes, check the trigger pin connected to OG wire from brake switch. The brake on off switch grounds this wire to trip the relay and turn lights on.
wire is shorted to ground somewhere including the switch.
If no, there's a short to battery inside or on other side of brake relay.
John
John
Received 10,980 Likes
annamiata
12-08-2019 02:56 PM
WaterDragon
05-11-2013 07:55 PM
Navionsam
05-21-2012 04:37 PM
charger12
04-04-2012 04:23 PM
