XJ6 Series 1 2.8 Radiator Tank
whatever fits the space should be fine. A reservoir tank is a reservoir tank. You might check a Series 2 or 3 tank to see if it fits. The Series 3 plastic tank has a low coolant sensor at the front, it can be plugged or left disconnected if not needed. Also there are universal/generic tanks that can be used.
jag68 (05-28-2017)
