XJ6 Series 1 (QUESTIONS OF ALL TYPES)
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
Hello All,
I have a 72 xj6, and I am in the middle of restoring/modifying/customizing/etc the car. I am creating this thread for anyone else doing the same.
To start off...
Anyone know about adding a rear swaybar to the car?
I am planning to LS swap the car, and am curious which modern GM transmissions will fit. I was thinking 700r4, 4l60, 4l80, or maybe a 6 speed, but I do not want to cut into the tunnel.
Any ideas?
I got a tone more questions, and have learned a lot. Please comment ideas/answers/or other questions.
Cheers!
-Jacob
To start off...
Any ideas?
Cheers!
-Jacob
Hi Jacob,
I have a 72 XJ6 I'm slowly restoring as well. Rather than lumping I have a V12 from a Pre-HE Jag going in probably next summer.
Anyway, a good place to start:
https://johnscars.com/xj.html
Keep us posted.
Jeff H.
Keep us posted.
Jeff H.
Hello All,
To start off...
-Jacob
To start off...
-Jacob
Greg in France (09-21-2022)
You don't need a sway bar. That function is built in to the design rather than tacked onto a primitive solid axle as an afterthought. My series 2 has a non-electronic 700r and is smooth as silk. It's a tight fit but there was no cutting necessary. One suggestion I would make at this early stage is to get the best available front and rear engine mounts available. Avoid the re-badged Chinese crap at all costs.
At any rate, there is to my knowledge no evidence that the Jag IRS has integral anti-roll properties even though it's not a solid axle. Both types of suspensions benefit from rear sway bars provided a good front one is fitted as well. Corvettes, for example, have rear anti-sway added to their IRS, although later cars utilize a specific transverse spring rather than a traditional roll bar. IMHO.
Jaguar fit a rear sway bar to some XJS models, which have the identical IRS to the S1-S3 XJ. They also increased the diameter of the front bar. I fit the larger (7/8" vs 11/16") front bar as well as the XJS rear bar to my 71 XJ6. I and others like that arrangement. The rear bar is fairly wimpy. Some prefer a stronger aftermarket rear bar plus a 1" aftermarket front bar.
Within the XJS camp there are those like me (and I hesitate to include my name with the great man and do so in all humility) and Norman Dewis who consider the addition of an ARB (sway bar) not only unnecessary but unbenificial. My experience is that the rear ARB in a properly set up (ride height, shocks, radius arms, camber toe castor, cage mounts etc, including both front and rear axles) XJS rear axle makes it noticeably worse. Ride height is especially critical at the rear, I have found.
It is essential to use ONLY metalstik bushes throughout the car's suspension to have it handling properly.
Also, it is a fact that Jaguar added and subtracted the rear ARB to the standard spec of the model several times in its life.
Equally there are those who consider it beneficial.
Now the saloon is different because the CoG and weight distribution are different, so there is no straightforward carry-over from the XJS to the saloon.
My own feeling is that it would be best to get the car bang on in standard spec, and then see what it handles like, and make additions to the rear if needed to get the car handling as you would like.
Received 9,209 Likes
When I traded my OEM front bar for a bigger V-12 bar last year, it Definitely changed handling.
Noticeably less sway, which means cornering is Way different! Almost flat!
In fact, on a tight turn I know, where I'm accustomed turning "this much," it doesn't need "that much. "
Husband wanted me to install a rear bar, but I think she's Just Fine right now.
The following 2 users liked this post by LnrB:
Greg in France (09-21-2022),
Jahmiata (09-21-2022)
Daniel Smith
07-25-2022 06:45 AM
drdrummerii
05-20-2013 10:18 AM
