XJ6 Series 3 stalls when engine cold
I have a Series 3 XJ6 here in Thailand which is UK spec (right hand drive and Emissions B). RHD is correct for here.
When I bought it a little over a year ago, it had been unused for about 5 or 6 years according to the vendor, and was not a runner. I have done a lot of work on the car and got it roadworthy now, after quite a long battle.
I have gone over the fuelling system on my car quite extensively, and the work done includes:
I have removed the Extra Air Valve and tested it. After chilling in the freezer, the orifice opens right up. At ambient temperature it is a little less than half open. When heated up with the hairdryer it closes to just a slit, and with 12V applied to the connector, it closes up completely. So the EAV seems to be working properly. I do have 12V and ground on the pins of the plug to it when the fuel pump is running.
Can anyone think of anything else I could try to prevent it from stalling when cold? I don’t want to increase the tickover setting any more as it is OK when hot, and in fact with A/C off in P it is up to about 1200 RPM anyway which is quite high. Over here, the A/C will be in use all the time as the climate is hot. I have not done much with the idle mixture adjustment on the AFM, other than tweak it a bit to get max idle then use the idle adjustment screw to set the required tickover.
Any suggestions you might have would be gratefully received.
- New fuel tanks
- New fuel pump
- New fuel filter
- 2 out of 3 solenoid valves for fuel changeover replaced
- All new hoses for the fuel system
- All injectors professionally cleaned, including the cold start one and new micro filters fitted
- Injector harness fitted with new connector plugs and all wiring metered out between ECU, AFM, Injectors, CTS etc. (I found two open circuit wires to AFM which had been causing over-rich running problems)
- New coolant temp sensor
- Throttle butterfly set to 2 thou’
- New hoses on Extra Air Valve and the air block with the idle adjustment. New breather vent boot.
- Fuel pressure checked at fuel rail and in spec
- Timing checked
- All vacuum hoses renewed and incorrect connection via ported vacuum from throttle body disconnected and plugged – vacuum connected to rear of manifold plenum. I am convinced there are no vacuum leaks any more.
- Idle set to 900 RPM with A/C on and transmission in P (this drops to about 550 RPM in D)
- Full throttle vacuum switch checked and working ok.
I have replaced the Coolant Temp Sensor
From what I understand about the Thermotime Switch, it only operates for a short period at start-up to activate the cold start injector. As the car starts easily from cold, I haven’t considered this to be a potential problem as I don’t think it does anything after start up
Received 10,980 Likes
You've covered a lot of bases.
One thing that comes to mind when discussing cold running problems is the double-fueling problem and fix.....
XJ 6 Series III 4.2 - Cold Start EFI Overfuelling
It's not an exact match for your symptom but might be worth a look.
More later. I'm only two sips into my first cuppa coffee and the brain isn't quite alive yet
The TT switch doesn't operate unless the key is in the 'start' position and the engine is stone cold
Thanks for the suggestion about the capacitor, Doug. If the engine is over-rich when cold, perhaps it could cause it to stall at low revs. Today I drove the car to town to buy a capacitor. I was watching the temperature gauge and the car stalled at the first three junctions with temp under 70C, but the next junction, by which time the gauge was at about 75-80C, it did not stall, nor did it thereafter. So the quoted figure of 72C in that bulletin sounds like more than coincidence.
I shall fit the capacitor tomorrow morning and report back if it makes any difference or not.
I'm not aware of a circuit identified that way.
However, there is a 'full load' circuit to enrich the fuel mixture under heavy load. It is operated by a mechanical switch. Is that what you're thinking of?
Received 2,399 Likes
From one unfamiliar with this engine management system:
1. 550 idle is a bit low for a cold engine. Is there a means of upping tht and not having too many idle RPm with the engine warm??
2. My idea of a good warm idle is as much as can be tolerated and not have transmission creep at a stop. Particularly with the AC on!!
Kudos, you have come a fur piece!!!
Carl
Carl
Andy, kindly do me a favour by showing me a photo of the capacitor you soldered, I need to check and try doing same to my car.
if you have before soldered and after soldered photos please send.
I need to see that capacitor
Mike
Can I get the whole cable unit to buy from SNG?
It looks very much like your car has had the capacitor mod in the past, but someone has removed it again. Perhaps they found it and did not know what it was for, so cut it out.
I would recommend fitting a new capacitor there. The taped wires are the two wires across which it is fitted.
New injector wiring harnesses are available from Autosparks but they are VERY expensive.
By the way, are you based in Accra? I was working in Ghana all through 2018 and loved it there. We started in Tamale and later were in Kintampo, Bimbila and Atebubu. Such friendly people everywhere.
