XJ6 Thermostat, Rubber Seal or Not?
In need of a new thermostat and I see some come with a rubber seal around the perimeter and some do not. Does it matter? Does brand matter?
My car isn't getting up to temperature and I assume the thermostat has failed in the open position. I shorted out the temperature sensor wire and confirmed the gauge is working, but the needle doesn't hardly get off the 50 mark. Tried two different temp sensors and they both read the same.
Fluke meter temps:
Radiator 94 degrees
Lower radiator hose 110 degrees
Upper radiator hose 89 degrees
Thermostat inlet 125 degrees
Coolant rail 125 degrees
Top center of head in the spark plug galley 190 degrees
Fluke meter temps:
Radiator 94 degrees
The following 3 users liked this post by Fraser Mitchell:
The following 2 users liked this post by Doug:
Grant Francis (11-19-2022),
JagCad (11-20-2022)
Due to teh fact Jaguar, and others very rarely specified simple things as unique to them, stats, temp sensers, temp sensors, etc etc, are used on many nmmakes and models.
Aftermarket regularly groups things in that way, so an o/ring could be supplied, wether it fits YOUR car is another discussion all together.
AJ6 had stat o/ring
AJ16 NO stat o/ring
V12' NO o/ring, gasket only.
That ledge the stat sits on MUST BE clean, so the stat sits nice and square.
Stat length is the most critical spec, and so many replacement stats are too short. They need to be 43mm fully open, and this applies to the XK 6cyl engine (S1,2,3) and all the V12 engines (except the carby version).
AJ6 had stat o/ring
AJ16 NO stat o/ring
Greg in France (11-20-2022)
I ended up ordering a 180-degree fail-safe Motorad from my local Napa. I will have to check the length when I get it.
Am I correct in assuming the 43mm is the overall length once open? To test just drop in some boiling water on the stove and measure it once it is fully open?
The following 4 users liked this post by Doug:
Bill Mac (11-22-2022),
David84XJ6 (11-21-2022),
Grant Francis (11-21-2022),
Greg in France (11-22-2022)
I bought my first S3 XJ6 which was a repossession with the head off (and in the trunk), I sorted it out and got it running. Timing chains, tensioner and bent inlet valves etc.
But it was not too economical only doing 16 to 17 miles per imperial gallon on the open road and seemed to run cold.
Eventually I twigged that the thermostat was keeping the engine cold, and it turned out somebody in the past had fitted a 70C/160F thermostat.
I fitted the correct 180F/80C thermostat and average fuel consumption improved to 20 to 21 MPG
The following 4 users liked this post by Bill Mac:
Doug (11-22-2022),
Grant Francis (11-23-2022),
Greg in France (11-22-2022),
littlelic69 (12-02-2022)
The following 3 users liked this post by MSGGrunt:
