xj6 vanden plas 1987
Guest
Posts: n/a
I am in the process of buying above mention car. Transmission quit working. I am very mechanically minded person. I have done many minor and major car repair but have not swap a transmission. I can get the used tranission very cheap. How difficult it is to change the transmission on this car? Please give some tips and advisces on this issue. I will appreciate this. Please!!!!!!!!!!
Sahai
Sahai
Tranny issue Heh not even hard
Okies for starters, since your Borg warner is dead in the water why go back to another? GEt a tranny that has over drive, plenty of easy install conversion kits to replace that standred 3 speed. And they are cheaper. Even an old 700r4 would be great and improve gas mileage
Guest
Posts: n/a
Thanks, Mr. James-
Atleast I found some body who can help me. I do not know what 700r4 transmission is. But I will not bother you for this. I will found out on the forum about it. I learned from the forum that chevy caprice transmission can be put. I have access to pick and pull junk yard place. I can pull old transmission for 100 dollars - any car. Now about the conversion kit. What conversion kit includes? What componants I need to convert?, torque converter? Drive shaft coupling? Any linkages or whole engine? Is it possible to keep the Jaguar engine? I looked at the transmission and I can see lot of space around the transmission bell housing. How difficult is to open those bell housing bolts, Any special tool is needed? Once again, Mr. James, I will appreciate your help.
Thanks.
Sahai
Thanks.
Sahai
conversion plate
Go online to http://www.johnscars.com/qb/xj6qb.html all you need is on that page, you WILLNOT regret dropping the borg warner
rusty37
04-05-2020 07:40 PM
WTB[NorthEast]: 1996 Vanden Plas Rims
kevinl
09-18-2015 11:00 AM
'05 Gold XJ8L VDP
09-18-2015 07:15 AM
