XJ6 white/blue wire plugs into what terminal on the starter relay?
Any help is appreciated.
I have a 1980 XJ6 and I can't figure out on the wiring diagram where the white/blue wire plugs onto the starter relay....
Thanks in advance....
Adam
Adam
Received 10,922 Likes
If you have a 4.2 you shouldn't need the white/blue. Was it ever hooked up? Did you trace it to see where it goes? It should just disappear in the harness and not connect to anything
If you have a 3.4 (with the old points type ignition) the white/blue goes to the same terminal as white/yellow (terminal C1) ....or a twin terminal to the white/yellow (terminal C4). Since the 3.4 uses a bypass resistor the white/blue is supposed to take 12v from the relay and send it to the coil "+" post when the starter is engaged.
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
09-02-2015 11:43 AM
