XJC Alternator Upgrade
I posted this separately from the other ALTERNATOR thread as I have a SII with a Lucas 20ACR that seems to be putting out less than 12v with A/C, headlights, radio on. Yes, first thing is I'll check all connections; the battery is new and doing its job. I've looked at threads in the past and have read about the upgrades. Is there anything new that someone would recommend if I decide to pull it and go with something else? My XJC is about to become my primary vehicle for a couple of months and I can't lay it up for more than an evening to accomplish any swap out.
Many thanks, Bill
Many thanks, Bill
Received 2,399 Likes
Bill:
If you are relying on the dash voltmeter alone, you might be mislead. Good as indicators only, and slow on the "uptake".
I made a patch cord for my HF sourced VOM. Plugs into the cigar outlet. I can read volts at various RPM's and loads, in real time. I thought I was a genius!!! Naah, plug in meters are on the market!! I exonorated my alternator and convicted my battery!!! New battery and all is well.
Thanks for that other thing. Done. Enjoy the fan addition
Carl
Carl
Many thanks, Bill
Many thanks, Bill
https://www.summitracing.com/parts/msd-5380
I did the swap (using the John's Cars kit) years ago and have been through two rebuilt 10si style alternators since then. This one has 100 AMPS and new - not overly pricey so I figured what the hell. Nice and red too (although you can't see it under the A/C Compressor - shame)!
