XJC rear side window removal question
Old 04-11-2018, 02:09 PM
littlelic69's Avatar
My series two was using water, I thought it was a failed her gasket, the cooling water tested positive for exhaust cases! I removed the head and discovered that there were three cracks between adjacent cylinder bores. There is a repair that entails removing the bore liners, machining a larger diameter ring into the top and replacing the standard liner with a "top hat" liner! I decided to find a so called slotted block from the series three, but use my carbs rather than the fuel injection system.
Old 05-11-2018, 01:54 PM
olivermarks's Avatar
Series 1 donor car rear door skin patch panel in rough position. I was careful to keep the top rolled over edge intact. Will probably glue as well as weld to allow for flex
njk1963
06-05-2017 07:54 PM
John Spry
12-29-2016 03:39 PM
Bunky Twincam
10-03-2015 02:28 PM
John Keith
03-17-2015 09:32 AM
smgdata
05-25-2014 01:03 PM
Quick Reply: XJC rear side window removal question
