1989 XJ-S Resto-Thread - or "my Iron Lady"
Old 10-06-2014, 04:02 AM
rgp's Avatar
rgp
rgp is offline
Originally Posted by Daim
Forgot the 0 at the end...
gotcha, cheers Daim
Daim (11-01-2014)
  #62
Old 10-06-2014, 12:57 PM
Brake buster's Avatar
bought one today from SNG
mine was ' ok ' but not what i wanted, so i think the £30 is worth it for the clean looks
i also have a new upper and lower column surround to fit that i bought years ago , with new fixings and an illusive square blanking plug that goes in it
anyone know what may have been fitted in that space on the left of the column cowl ??
BB
Daim (11-01-2014)
  #63
Old 10-06-2014, 01:36 PM
Daim's Avatar
Received 2,181 Likes on 1,584 Posts
I've got a little switch for the factory alarm system in that spot...
  #64
Old 10-06-2014, 01:59 PM
ah !
i remember now
mine had a factory alarm ten years ago before i ripped it out ,
you should have the red LED in between the window switches as well then
BB
Daim (11-01-2014)
  #65
Old 10-07-2014, 06:02 AM
Daim's Avatar
Originally Posted by Brake buster
ah !
i remember now
BB
My LED sits on the steering column. About an inch or two away from the switch.
  #66
Old 10-07-2014, 01:03 PM
Daim's Avatar
Picked up the blasted parts today. Beautiful! Lovely job!
Before:
After:
Now just got to refit everything again
  #67
Old 10-07-2014, 01:57 PM
looking good
can i ask , are you protecting any of the steel parts from corroding again , as they will go rusty quite quickly if not painted or lacquered as they were originally anodised or cherodised ( sp?) for protection
BB
Daim (11-01-2014)
  #68
Old 10-07-2014, 01:58 PM
Daim's Avatar
The Steel parts are being replaced by new parts
  #69
Old 10-23-2014, 12:32 PM
Daim's Avatar
Well then... I started to assemble the intakes/plenums again... And they look nice. Sandblasted, cleaned and new parts... Just the throttle bodies could be cleaner but heck, the engine will get dirty sometime again!
Missing parts:
Vacume hose for distributor:
Intake re-assembly:
Just a lot more to do yet Hopefully ready by the weekend! Can't wait to hear that V12 start up again!!!
Greg in France (10-24-2014)
  #70
Old 10-25-2014, 11:42 AM
Daim's Avatar
Okay, more detailed pictures
I love it already! A few little things were moved from where they used to live (temperatur sensor/switch, ground terminal, piping, etc.) and a few little changed to other details like the balance pipe (now black instead of standard steel) and it is already looking nice and tidy! Hopefully she'll be ready tomorrow!
  #71
Old 11-01-2014, 04:28 AM
Daim's Avatar
Getting there - slowly!
Did the rubber mounting rings of all 12 injectors last night.
Followed by doing the HT leads nicely - and tidily! Nothing worse than cables and leads dangling around!
And I also did a first time thing since around about May... I closed the bonnet!!!
  #72
Old 11-01-2014, 05:00 AM
well done
keep at it
when installing the injectors into the inlet manifold you need to be aware of the way the plugs face, they are not all the time direction, or in any pattern , your injector loom will be the best guide
BB
Daim (11-01-2014)
  #73
Old 11-01-2014, 05:04 AM
Daim's Avatar
well done
keep at it
BB
Hi BB,
cheers...
The injectors will face differently with my loom. They'll be grouped in pairs facing each other I prefer a more "equal" look
  #74
Old 11-01-2014, 05:47 AM
cool
make sure the retaining clamp is also correct, as they can not be turned over once the rail is fitted
looking good
BB
Daim (11-01-2014)
  #75
Old 11-01-2014, 05:49 AM
Daim's Avatar
That is of course the most important thing I was going to fit the injectors, see how much clearance is there and then decide after that...
Just can't do it today... Tomorrow
  #76
Old 12-13-2014, 11:41 AM
Daim's Avatar
More than a month passed and no new updates!? Can't be!
So here she is, sitting outside (still not totally finished) and losing her oil as we speak (drop by drop... She's had PMT for like 12 months now...):
And the engine bay is still shiny and not finished. I experienced some issues with the fuel injectors... And at the same time finding the odd hose which wouldn't sit properly. But otherwise she's nearly ready for her start up:
At the same time, I am sorting the air filter boxes out. They were all rusty around the edges and I think a nice and clean engine should have some rustfree boxes.
A few parts are to arrive this week coming and I should then be able to have them in by Xmas... Looking forward to hearing this piece of art purr again
  #77
Old 12-13-2014, 02:05 PM
TheWarlock's Avatar
that engine bay looks fantatic, Diam. Looks like you've tidied up the wiring and vacuum lines quite a bit. Can you share some details on this aspect?
Daim (12-13-2014)
  #78
Old 12-13-2014, 02:27 PM
Daim's Avatar
It's not finished yet, as some parts are still being worked on.
My intension was to only have those hoses visible, which are needed to be in that place. For example the vacume switch, which sits on the rear end of the right hand intake, was moved a few inches back and is now mounted to the triangular end bracket/housing of the intake. The vacume hoses to and from that area are all running in that area only.
The hose for the cruise control actuator actually used to run to the front of the engine, along the valve cover and then clipped to the intake. That now runs under the intake and is totally invisble.
The cables for both sides used to run along the intake manifolds and then lead to the front. I've moved them to under the intakes but out of the V. The injector cables will be sorted too, as they aren't in the picture there. They'll be moved under the intakes too Just enough not to get too hot as in the V area
In the picture above, there are a few hoses just running chaotically around, as I had to seal a few holes before I could store the car outside. But when finished, I'll take some detailed pictures of how the piping runs. The pipes are now - btw- silicone instead of rubber, as silicone is better for high temperatures (which are common in this engine bay)...
TheWarlock (12-14-2014)
  #79
Old 12-13-2014, 02:42 PM
warrjon's Avatar
Received 2,576 Likes on 1,712 Posts
Good work.
Are you going to clean the injectors before re-installing?
Daim (12-14-2014)
  #80
Old 12-13-2014, 02:55 PM
Daim's Avatar
They are spotless... I haven't cleaned them externally, as they won't be seen in full sight when fitted. Internally they are/were clean. I've just got to install some new pintle caps as one has broken and all other 11 are not far from the same. So they'll all be sorted when the next parcel arrives
Quick Reply: 1989 XJ-S Resto-Thread - or "my Iron Lady"
