Ask me them stereo questions!
Old 12-26-2012, 10:48 PM
jake21's Avatar
Default Ask me them stereo questions!
Lately I have seen a few stereo questions pop up around here, so i figured I would make a thread for the purpose of answering you car audio, security, remote starts, bluetooth, gps, etc etc etc related questions in our Jag's.
I have been a professional car audio installer for many years, so if you have any 12v questions, feel free to ask.
The following 3 users liked this post by jake21:
gamtlee (01-15-2023), RobertL (11-07-2014), Stuart48 (10-30-2015)
Old 12-27-2012, 02:45 AM
Greg in France's Avatar
Received 9,333 Likes on 5,476 Posts
Jake
My radio/CD player goes click click click in time with the revs when in radio mode. Does not happen on the CD when it is playing. What can I do to stop it please?
Greg
Old 12-27-2012, 08:25 AM
jake21's Avatar
Jake
Greg
Sounds like a ground (earth) issue. Ground your antenna to a solid piece of metal in the vehicle, and ground your stereo to metal also, if you can ground them both at the same location.
If that doesn't work, run a new constant (12v) line from the stereo directly to the battery.
Guess I forgot to ask, are you running any amps?
jake21's Avatar
And are you running a power antenna?
Old 12-27-2012, 08:28 AM
Power antennae: yes
Amp: no
Greg
Old 12-28-2012, 09:57 AM
shula's Avatar
Default Do I have a Stereo Amp?
How can I tell if the stereo amp is working? 2003 X-Type, 2.5, nav system with touch screen origional equip.
Old 12-28-2012, 01:26 PM
jake21's Avatar
If you have sound, its working. Do you know if it amps all of the speakers or just a few?
Old 12-28-2012, 01:30 PM
jake21's Avatar
Power antennae: yes
Amp: no
Greg
Definitely make a new ground for the antenna and radio. What you are getting is called "engine whine" Basically the ground for either or has gone bad in the vehicle thus the outer shielding on the antenna wire isnt doing its job, it is receiving EMI (electro magnetic interference) from somewhere in the vehicle. To make the shielding protect against EMI it needs to be grounded at the radio, and antenna mast
A simple way to check if that is the problem is to take a scrap piece of wire, touch the outer most part of the metal antenna plug and attach it to the negative post on the battery
Old 12-28-2012, 02:33 PM
shula's Avatar
Default How do I know if my stereo has an amp
I replaced all the speakers in the doors so I get sound now.
Old 12-28-2012, 02:43 PM
jake21's Avatar
You do or do not get sound now?
Can you go into more detail about how you went about replacing the speakers?
Did you run new wires to each individual speaker from the head unit, or did you use the existing wiring?
Were the stock speakers playing sound? Or did you replace them because they were not?
Old 12-29-2012, 12:40 PM
shula's Avatar
I got a muffled sound, so replaced all the door speakers. Sounds OK to me but the wife says just don't sound as good as before. I replaced with better speakers than the stock speakers. Thanks
Old 12-29-2012, 12:42 PM
jake21's Avatar
Do you have tweeters? And did you replace them?
Old 12-29-2012, 08:27 PM
gregh's Avatar
Default Speaker sound
-Last year, I replaced all four stock speakers in my '89XJS with 6.5" round Pioneer speakers, and the sound improvement was so good, I almost kept the stock cassette radio system in the car, but I had already bought the Pioneer deck with CD,MP3, and USB ports.
The new speakers were great.
Old 12-30-2012, 04:13 PM
jake21's Avatar
His will sound good once we figure out the way it's wired, stock amplifiers can be complicated on how they are wired, they usually have internal crossovers built in and most aftermarket speakers are made to be used in full range or with external crossovers , they trick is to find out what kind of signal is being sent through a certain wire from the stock amp and pair it with the right type of speaker I.e.) low mid range signal for larger speakers and high range for tweeters
Old 12-30-2012, 04:16 PM
jake21's Avatar
Honestly, it is going to sound 100% better if you opt for a new head unit and wore it directly to the speakers, and if there is a stock sub, leave it wired to the stock amp
Old 01-06-2013, 01:30 PM
ianb's Avatar
Default 03 x type
I am getting a lot of interference through my radio oncertain staions ( medium wave)and back ground hiss between stations is there anything I can do to resolve this.
Ianb
Old 01-14-2013, 10:29 AM
Terry's Avatar
Jake,
This isn't Jag related, but, I thought I'd throw it out there. My DD is an '08 Jeep Wrangler. I am wondering if there is a way to disable the horn honk feature when you lock the car with the remote fob. I have never liked that on any car and I hate it when it's my car. I get home late a lot of nights, and I hate disturbing the neighbors. I don't really care if it also disables the alarm, nobody pays any attention to them anyway. You audio guys always seem to know about alarms.
Thanks, Terry
Old 01-14-2013, 01:48 PM
ATL Dave's Avatar
Re: Terry and the honking jeep.
That is a programming thing the dealer can do in jus a minute. They should do it fro free... But they have to plug their computer into the car, then they can disable tht option.
I used to have a Sebring as a company car, and had them do the same thing.
Dave
Old 01-16-2013, 01:33 PM
DenverDRS's Avatar
Hey Terry, I have a '12 Rubicon. The honk function can be disabled in the "personalize menu" section using the toggles on the front, left side of the steering wheel. If your '08 has a menu option, use the arrows to see if you have the same drill down.
Good luck!
Old 01-16-2013, 09:54 PM
kmrod22's Avatar
A little late to this party but hopefully I can get some help. I've got an 03 STR and would like to be able to stream audio from my phone or an ipod. Is there any way to do it other than an FM modulator. Is there a way to use the CD changer port by chance.
Quick Reply: Ask me them stereo questions!
