King Springs for the XJS
How many people are interested in getting King Springs (very high quality) aftermarket springs, available in standard or lowered heights (30mm), from Australia WITHOUT the enormous shipping fee? I may have found a way...
Please look over the graphic below and let me know if anything looks off. I, and anyone else interested in getting in on this buy from King, would have to order them tonight/tomorrow morning at the latest.
Many thanks in advance for any and all advice.
Seth
Seth
Springs ordered. Shipping from the US distributor is only $20, springs were $475. BUT, I have to wait 1.5 months for the container ship to make it from Australia to the US distributor on the West Coast and clear customs. To save over $200 on shipping, though, it was well worth it.
Calvin, I'd still love to know which spring numbers you ordered and what engine you have.
How much further does the front need to come down? And how many miles have you driven it? The last car I lowered with aftermarket coils took a few weeks for the coils to come to a final set. When I first installed them the car came down .5" After a few weeks of driving, it finally settled at 1.5". I've read on some forums where it takes new springs a few hours of driving to settle down—others have said two months.
If you're convinced the springs aren't going to come down as far as is needed, you may want to try to exchange them for one of the two shorter/weaker types used to lower a 6-cylinder XJ6, or else add spacers below the spring pan as Warren mentioned. What I'm told comes from Jaguar is that the car is lowered by 2.5 times the thickness of the spacer (each 1/8" of spacing lowers the car 5/16"), so it would only take a .4" spacer to get the front down 1", or a 1" spacer will lower the car by 2.5", but then you've got slightly less ground clearance beneath the spring pan.
ive driven it maybe 20 miles, and ive removes all the spacers from the front end. ill see when i get everything together, im converned when i did the trans swap it took a lot of weight away, turbo 400 and t5 are very much different in weight and i used an aluminum driveshaft, which was like a quarter of the weight of the orignal one. ill post a picture up in a little bit of my ride height
1964Daimler
09-09-2015 11:28 AM
Tar
09-06-2015 11:24 AM
