Marelli Rotor Fix w/Photos
HOW TO: Marelli Rotor Fix w/Photos
Today I performed the Marelli Rotor Fix on my 1990 XJS 5.3L V12.
After seeing many request for how this is done, I decided to document how I performed this procedure. Some folks might do this in a different way but this is how I did it and it works fine.
PROCEDURE
Remove the Distributor Cap and Rotor.
You will notice that the Marelli distributor does not have any vacuum or centrifugal advance mechanism. All timing/ignition advance is controlled by the ECU. The distributor is only used to pass spark to each plug in the correct order.
To eliminate any chance of metal filings entering the distributor or engine I decided to remove the distributor.
Before I did so I place a few punch marks to insure I could replace the distributor and rotor in the exact original postition.
It is not necessary but if you wanted to you could turn the engine until the 1A piston was at top dead center, then make your punch markings.
Remove the 3 bolts and the distributor will lift right out of the engine. Here it is after being removed and cleaned.
Just for reference, here are some of the markings on my distributor.
Is case the photo is not clear the numbers read as "DT409A --> OE DAC 4758"
Using a grinder, cut-off wheel or hack saw remove the metal nub that normally extends into the rotor. Use a file to make everything smooth.
When that is finished thoroughly clean the distributor to remove any metal filings.
Here is the bottom of a new, unmodified rotor.
Fill the rotor with RTV Silicone.
Normally I would use a clear RTV but I had a tube of black on hand and it works just as well.
Before reinstalling the distributor, clean the flat area where the distributor mounts into the engine.
Now reinstall the distributor and secure with the 3 bolts.
Install the new rotor and distributor cap and you are finished.
PROCEDURE
The following 12 users liked this post by Safari:
1100me (09-27-2015),
Bc xj (01-19-2015),
Brake buster (01-18-2015),
Doug (01-17-2015),
Flint Ironstag (01-18-2015),
and 7 others liked this post.
It's much easier to do if you take out the distributor. That also allows you to easily clean out the metal bits.
Mark
I performed this fix while I was replacing the spark plugs and doing a clean-up of the "V".
To make access easier I removed the AC Compressor, Cruise Control Bellows and the Throttle Tower.
Mark
XJSFan (01-19-2015)
aholbro1
08-05-2021 05:02 AM
