Programming remotes on 94-96 XJS video
Old 11-26-2012, 01:31 PM
Spikepaga's Avatar
Default Programming remotes on 94-96 XJS video
Hello guys!!
I made this video on how to program the remotes on a 94-96 XJS with alarm module Dpp 1050 on the US or Dpp 1051 in the UK. I tried to make it a clean as I could but I am not a professional, so please excuse my errors.
Couple of disclosures, I am not responsible for damage to yourself or your vehicle. This is just a video of how I have programmed my car and how many others have done it as well:
The following 3 users liked this post by Spikepaga:
dsetter (12-15-2012), scarbro2011 (01-25-2014), Spillwaybob (01-23-2014)
Old 01-23-2014, 08:23 AM
Spillwaybob's Avatar
Mark,
Excellent video with good information. Thanks for sharing it with us.
Unfortunately I won't be able to use it on my car as I found out that the remote I was trying to program is not the correct one for my car. I really did not need it but it would have been nice to have a spare "just in case"!
Take care,
Bob (Spillwaybob)
Old 07-13-2014, 01:19 PM
RobertL's Avatar
Thanks, works well. Video helps, xj6 valet switch works on my 1996 xjs . Great info.
Softball60 (10-24-2021)
Old 01-25-2017, 04:07 PM
Benj628's Avatar
Used your video to program my '96 keyless. Worked like a charm after I figured out that the switch I used was a push-button on/off and not on/off per push. Thanks!!!
As for remote compatibility, the one I bought had the following info:
1993 1994 1995 Jaguar XJ6 XJS Fob Remote
G57JTX318
DBC10084 318MHZ
DOC/MOC 1808 K1006
Old 06-24-2020, 12:57 PM
benzjag's Avatar
I did exactly like your video, but my 94 will not go into the program mode. When I disconnect the battery and reconnect, I hear the chirp but I cannot get the car to go into the program mode! HELP!
Richard
Old 06-24-2020, 02:42 PM
Benj628's Avatar
Disconnecting the battery has nothing to do with programming the remote.
Keep keep trying because it does take multiple times to get it to enter programming mode. You have to do it just right. Based on your model year you should have the switch installed from the factory whereas I had to add mine. Try increasing the number of times you flip the switch each time. Do one extra flip or one less and see if that helps.
Old 06-25-2020, 02:43 PM
benzjag's Avatar
BENJ628...You were right on! I increased the flipping of switch to about 10 times (instead of the mentioned 5) and the car went into the program mode. My new replacement FOB now works perfectly. FWIW, I bought it on EBAY for only $13.71 with free shipping. Thanks sincerely for reaching out!
Richard
https://www.ebay.com/itm/401538278137
Rick25 (07-17-2020)
Old 10-23-2021, 04:33 PM
JAGUNUT1's Avatar
Default Programming remotes on 94-96 XJS video is no longer available.
Originally Posted by Spikepaga
Hello guys!!
How to program keyless entry remotes on a 94-96 Jaguar XJS - YouTube
This video is no longer available. can you re-post or are there written instruction?
stpierrema (11-12-2021)
Old 10-23-2021, 04:44 PM
Benj628's Avatar
The viewing for your video is set to private. You will need to change that setting on YouTube for everyone else to be able to see it.
Old 10-23-2021, 05:14 PM
malc4d's Avatar
Old 11-03-2021, 11:00 AM
niala3's Avatar
Hello,
I do not kow if you are still active on this forum but could you please repost or send me this video please ?
Alain
Old 11-05-2021, 08:43 AM
malc4d's Avatar
Sirjagelot (03-03-2022)
Old 11-05-2021, 10:26 AM
niala3's Avatar
Thanks for the video. Do you know where I could still buy this OEM remote shown in this video please for an 1996 XJS convertible ? Seems not to be on the market anymore...
Old 11-05-2021, 04:18 PM
malc4d's Avatar
You can sometimes see them on Ebay. First you must know the frequency of the alarm. I believe that if its not a US import the French used 433 MHZ. If a US car that should be 318 MHZ.
Genuine Security System For Jaguar Xjs Sports Coupe/convertible 1975 - 1996 Classic | Jaguar Land Rover Classic Parts
Old 02-13-2022, 09:55 PM
seacat's Avatar
Default can we get a repost or the 'private' removed?
I have 1 1996 xjs and woudl like to have the previously posted video made available if possible?
Berkay (02-15-2022)
Old 02-15-2022, 01:03 PM
Berkay's Avatar
I'd like to watch the video too since i've similar problems. That would be really helpful if the owner of the video shares the video again or changes its status.
Old 02-15-2022, 08:24 PM
jal1234's Avatar
Did you look at post 12 in this thread? Video works fine.
Old 02-16-2022, 10:55 AM
Berkay's Avatar
I couldn't find the momentary contact switch in my car. That's why i thought the the video at post 1 might be useful to solve the problem. Does momentary contact switch exist in all xjs?
Old 02-16-2022, 09:51 PM
Vee's Avatar
Vee
Vee is offline
Received 1,562 Likes on 1,213 Posts
Does for the the 95 and 96. 1994? Maybe.
I thought the cars before the 95/96 model years have a more straight forward way to program remotes.
Old 03-03-2022, 03:42 PM
kansanbrit's Avatar
You have to provide the switch but the wires are there. I am the person who made the video.
Quick Reply: Programming remotes on 94-96 XJS video
