Rebuild photos
Guys
Here is a link to a slideshow showing what I did on my rebuild. I warn you that there are about 180 shots. I have put some explanatory notes on each photo:
Image hosting, free photo sharing & video sharing at Photobucket
I had two cars, both the same age, and I took the better shell and put the better mechanicals into it. As you will notice, I cannot afford a respray yet! But the car goes really well and is an absolute dream to drive.
If anyone has any questions about what I did, please do not hesitate to ask away.
Greg
Greg
The following 6 users liked this post by Greg in France:
Doug (04-21-2012),
JJS- Florida (12-25-2023),
leep123 (12-26-2023),
mrtalkradio (04-24-2012),
Norri (04-19-2012),
and 1 others liked this post.
Received 6,326 Likes
That's immpressive Greg, I'll bet Rory had a blast!
I can't imagine where I could find someone to do the solder job on the tank here.
That bearing spacer must have been a guddle to get just right.
My only complaint was I couldn't find a way to pause the slideshow, even at slow it was too fast sometimes, could be operator error!
There was no need to point out the rev counter to prove it was running the smile in the next pic says it all!
![Icon Smile](https://www.jaguarforums.com/forum/images/smilies/icon_smile.gif)
There was no need to point out the rev counter to prove it was running the smile in the next pic says it all!![Icon Smile](https://www.jaguarforums.com/forum/images/smilies/icon_smile.gif)
http://s1010.photobucket.com/albums/...t=DSCF3122.jpg
Greg
Greg
Hole nearest the front 4mm. Second hole 11mm. Rear water manifold unchanged. But if you are a racer there are further mods that Mr. Lutz recommends, including larger water rail pipes and slight mod to rear manifold sizes.
Apparently these further mods were Tom Walkinshaw's answer to evening out the water temperatures along the block in his racing XJSs in the mid 80s. The 'stage 1' mods I have done work fine for fast road use, I am told.
One slight effect is that the temperature gauge reads a touch higher than before. This is because the cooler water being pushed into the block by the water pump no longer preferentially 'short circuits' out through the front exits points on the heads.
Correct. LHD XJSs were sold in France in some numbers, you still see them in Paris occasionally, and they come up for sale quite regularly. Prices for equivalent condition XJSs in France are much higher than in the UK for some reason.
Greg
Greg
Your welding needs some help
Weld hotter, feed faster and move super fast, so metal does not burn through.
It is also interesting how your car rusted differently from mine, even though mine was a real turd, before I started cutting our sections and replacing with fresh donor parts. You can see some pics here: https://www.jaguarforums.com/forum/x...st-here-55680/
One question, what type of gray primer are you using in these pictures?
This shell was relatively un-rusty because it had been in a lock-up garage for the last 20 years. The other car, which had been used all the time, was shot everywhere, floors, wheelarches, screen valence, all the usual places. It was the disappointment of this that made me determined to protect the rebuild as well as I possibly could.
Welds not too pretty I agree, but I guarantee you this, they are very strong!
Greg
We have similar thing, called DryLock. Wicked white stuff, used to make basements water tight and when applied on any surface, it prevents water penetration. I was thinking of using it, but decided to go with wax based amber rust proofing for cavities and self etching primer + Pickup truck bed liner + black wax based rust proofing on the outside.
Received 10,916 Likes
Hi Greg, I'm following your thread, someone compared my work to yours which is a great compliment. I'll be adding to the photobucket until I have had too much wine to get it right. I was supposed to be removing my fuel rail today to see how many injectors I fried by shorting out the Orange/White wire from the ECU during my welding but it was too depressing so I'm here at the PC instead.
