Removing instrument panel
Old 03-28-2012, 01:02 PM
Jack07's Avatar
Default Removing instrument panel
Can anyone help me, trying to get to the back of the speedometer. How do you remove the instrument panel out of the dash on a 1987 XJS V12? While I'm here how do you get to the damper plate on the floor heat vents? Getting heat through defrost vents but blows extremely cold air on my feet!! Thanks this is my first time here!!
Old 03-28-2012, 01:18 PM
Darel's Avatar
3 screws hold the 2 halves of the surround in place, one on each side you can see then one under that little centerpiece at the top-center of the binnacle. Remove the 2 halves. You may find it easier to loosen or remove the ignition and headlight switchplates to get them out.
Then undo the 2 screws you can see at the top and slide out the warning light cluster (if you can't see screws pop off the little plastic plates on either end of the warning light cluster that LOOK like they are blank-off plates for more warning lights - they are screw covers).
Then undo the 2 screws revealed by doing that and your cluster is free.
Then good luck fiddling the cluster out of the way without removing the steering wheel (which is itself a 5-minute job anyway).
Jack07 (03-28-2012)
Old 03-28-2012, 01:36 PM
Jack07's Avatar
Thanks! I got as far as the two hidden screws behind the cover plate!
Old 03-28-2012, 03:41 PM
Darel's Avatar
OK, then the message lights will slide out in a row, and then there will be two more screws behind that and that's it.
Old 03-30-2012, 01:37 PM
Jack07's Avatar
Thanks Darel for all the info I plan on getting to it this weekend. I'll let you know how it worked out!
Old 03-30-2012, 03:33 PM
Darel's Avatar
No problem...I do recommend removing the steering wheel, though, it will be VERY frustrating trying to get the cluster out with it in place. You can undo the grub screw, and the 3 tiny screws that hold the backing plate on and it slides right out, less than 5 minutes.
Old 04-02-2012, 06:18 PM
Jack07's Avatar
Thanks again, got it out and back in! My '87 xjs v12 must be a little different than your '85 xj-s he coupe. your advice was very helpful!
Old 04-03-2012, 01:01 PM
Darel's Avatar
Shouldn't really be different, maybe I'm describing something incorrectly. What differed from my account?
Either way, glad the job got done!
Darel
cissdm
05-03-2016 06:02 AM
rsa760041
23
09-25-2015 01:33 PM
sadepol01
09-11-2015 05:26 AM
1964Daimler
09-09-2015 11:28 AM
AL NZ
09-04-2015 08:39 PM
Quick Reply: Removing instrument panel
