‘87 XJ-S Stuck bonnet / hood
See post #25 in this thread:https://www.jaguarforums.com/forum/x...2/#post2600140
Edit: Nevermind, wrong yrar. Sorry!
On an '87 the hood closing mechanism is explained here on this sticky:
https://www.jaguarforums.com/forum/x...hanism-262397/
Now if your hood is stuck closed, and the cabin lever is in the open position, then the catches, or one of them has failed to spring open. I suggest that you unscrew the radiator grille and then that should allow you to unbolt the hinges. Once this is done, with the help of a second person, wriggle/joggle the hood from the front and see if the catches give enough to pull the hood out forwards.
Worst case you can cut the hinges and replace them if you cannot get to their bolts.
2020mike (05-15-2023)
hilaryv215
01-12-2015 03:21 AM
