11.5 Compression? Holy Octane, Batman...
I was just reading the Owner's Manual (for the first time), and, I noticed the XJS has a compression of 11.5 to 1. Uh, shouldn't I be using premium gas? I've been using 87 octane all this time. There is no pinging. What is recommended? What do the other club members use?
Greg in France (09-24-2020),
orangeblossom (09-27-2020)
after 1980 England and the rest of the world got 12.1-1 compression while America got 11.5-1.
The early car 1975-1980 had 40 degrees of timing while the HE only has 17 degrees of timing.
what does that mean to you? If you drive it gently you’ll get by for a while using 87 octane. Eventually you’ll burn valves and maybe put holes in your pistons. And spend a lot of money getting it fixed or selling it cheap to someone who will fix it.
91-92 octane will prevent that.
I know all the talk about premium is a waste of money. Not all the time!! Most cars run fine on 87 octane. Not Jaguars.
