16” 8j rims
Old 06-13-2018, 07:53 AM
brinny's Avatar
Default 16” 8j rims
Will 8j tyres fit on the xjs ok would anyone know? Thanks for your help
Old 06-13-2018, 09:28 AM
brinny's Avatar
No mention of issues in palms book if anything they are advocated. Sorted.
Old 06-13-2018, 03:35 PM
Jagboi64's Avatar
Received 3,145 Likes on 2,080 Posts
They fit on an XJ40 and X300, so probably would be fine on an XJS.
Old 06-14-2018, 01:04 AM
Greg in France's Avatar
Received 9,251 Likes on 5,433 Posts
What did you buy Brinnie? Got a snap?
Old 06-14-2018, 08:26 AM
brinny's Avatar
Not bought any yet. Would like some lattice alloys in 16” but can’t find a set at a reasonable price. Wanted to double check they fit.
Old 06-14-2018, 10:02 AM
There is a set of 16 inch TWRs on the dock of the bay for 400 quid.
Old 06-14-2018, 03:50 PM
warrjon's Avatar
Received 2,576 Likes on 1,712 Posts
16x8 will fit but you need different offset front and rear.
Rear offset +33
Front offset +20 TWR used +19
Greg in France (06-15-2018)
Old 06-15-2018, 06:25 AM
brinny's Avatar
By offset do you mean tyre size?
Old 06-15-2018, 06:38 AM
bladerunner919's Avatar
Offset is to do with how far the mating surface of the wheel/hub is from the edge of the wheel. It's probably best to look at something like this to explain: https://www.tsw.com/explore-tsw-cust...eel-offset.php
Old 06-15-2018, 06:43 AM
rgp's Avatar
rgp
rgp is offline
I FITTED 7" front and 8" rears lattice some time back they are RW MACHO
better quality that the fondmetal versions imo both have 22 written after the size markings
Attached Thumbnails -100_7968.jpg   -100_7969.jpg   -100_7970.jpg   -100_7971.jpg   -100_7972.jpg
Old 06-15-2018, 07:06 AM
brinny's Avatar
I think I understand. Does this mean I can’t just bolt the wheels on? And if not how is it sorted? I’ve a chance of four 16” x8j wheels do I have to mess about using spacers? Can do without the hassle.
Old 06-15-2018, 07:10 AM
brinny's Avatar
Where did you get them from? Did you have to buy two sets? If so have you a set left over lol
Old 06-15-2018, 07:33 AM
I don't know the answer to your specific question, but if you go to this site you can enter the details of your current wheels and the spec of whatever you are proposing to fit, and you can see how it will sit differently and whether you need spacers or will have problems with rubbing, etc. https://www.willtheyfit.com/
Old 06-15-2018, 07:58 AM
brinny's Avatar
Thanks for the link. I put in tyre sizes as best I could and it said the outer rim will be plus 1mm which i# neither here nor there, th3 inner it said would increase 39 mm. Didn’t know this would b3 so difficult. Might just leave th3 15 s on.
Old 06-15-2018, 10:20 AM
rgp's Avatar
rgp
rgp is offline
I bought them in the 90s from an ad in jaguar world, just a full set of 4, I have a space saver as a spare but that will only be suitable for the front as its slightly bigger diam. than the rears.
Old 06-15-2018, 04:53 PM
warrjon's Avatar
No, offset is the distance from the wheel mating surface to the centre line of the wheel.
Decreasing offset moves the wheel out.
I have a set of 16x8 BBS with 245-50/16 and are XJ40 fitment +33 offset. The rears fit without modification but the front needed to be spaced 13mm out or the inside of the rim will interfere with the suspension.
Old 06-15-2018, 05:39 PM
VancouverXJ6's Avatar
These??
Old 06-16-2018, 03:11 AM
Edelweiss's Avatar
Well, I'm looking for a set like that... Where can I find them?
Old 06-16-2018, 04:17 AM
brinny's Avatar
Rear offset +33
Would you explain this a bit more please.
Old 06-16-2018, 05:37 AM
rgp's Avatar
rgp
rgp is offline
just got a reply from a new wheel supplier who doesn't list xjs on the choices list, and I forgot about this, that the centre caps wont stay put if flat on the wheel as the rear stick out and the front stick out even more, that's probably another reason you will need spacers.
Hello, I think we don't have it listed on the website as the wheel centre is the problem. From memory i think the they have long drive shafts which pop the caps out. The wheels need to have raised caps to allow for the clearance & most new wheels have flat caps."
Quick Reply: 16” 8j rims
