17x8.5 wheels
Seen a lot of posts bout 8" wide wheels and read SpyHunter's great thread about offsets.
I'm looking at a set of ARC AR01 wheels with the following specs:
8.5 wide
+35 offset
With 245/50 tires (which very nearly preserves stock overall diameter), I believe the rear will clear the inner fender liner.
The front is what concerns me while reading up on the subject. SpyHunter states at 8 inches, +25 is about perfect in the front. Is 8.5 flat out impossible then? I would only go 225 with the front tires, which should help.
Other option is some Petrol P4C's at 17X8, also +35 offset. Rear should clear just fine and the fronts would need a spacer. But I much prefer the looks of the AR01's.
8.5 wide
+35 offset
MrAndersonGCC (05-29-2024)
![](https://cimg5.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1427x856/2024_05_29_09_43_01_be83384b4986f5b1dbe34a92c868427b6d9c3ee3.jpg)
rickbetenbough
08-29-2014 08:16 AM
