1976 xjs a/c ranco ?
Received 10,979 Likes
The Ranco thermostat is in the circuit, yes, but, more specifically, its job is to deactivate the compressor if the evaporator gets close to freezing.
The compressor circuit is powered-up via the servo. I'm not familiar with the older circuit design but there might be a relay involved ...in which case the servo triggers the relay.
In any case, a faulty (or disconnected) Ranco can prevent the compressor from engaging
Kriss Vector (09-06-2021)
