1976 XJS Transforming into Modern Resto Mod
I thought I would share a few pictures of my modernizing the 1976 shell car that I purchased 4 years ago and have been throwing money at to bring into the 21st century .
Some of the highlights are
Complete LS Engine/trans computer
Push Button Start/ Remote/ Alarm
Dakota Digital Instrument Panel
Cruise Control relocation
Vintage Air
New Wiring Harness from both the engine compartment and from the firewall back
Halo/ Led Lights Headlights
Interior Led Lights
New Gas Tank with in tank elec fuel pump
Front/ Rear Cams
After Market Wheels
Fresh Interior
Updated Trunk Kit
Kenwood Stereo system
I ordered the headlights off of ebay from a company called octane lighting , They were under $300.00 and I also purchased the optional lighting switch so you can run the Halo lights as daytime running lights
https://www.ebay.com/usr/octane_ligh...53.m2749.l2754
Just put Halo Headlights and Jaguar XJS and your year model in the search function and it should give you many options, I like the solid Halo Rings and not the smaller bulb halo rings but that is just my taste.
The Jaguar logo lights are called Ghost /shadow lights and they make two models of these . 1) Model you hardwire in 2) Model that uses batteries
They were less than $30.00 and they have a few different options in logo designs you can chose from. Make sure you wire them to your interior lights and not regular lights so they only come on when the interior lights are activated by door opening )
https://www.ebay.com/sch/i.html?_fro...ights&_sacat=0
Received 10,979 Likes
I actually purchased my vintage air from a guy selling it unused on Craigslist for $500 dollars . The vintage air systems usually run around $1,000-1500 for complete universal sets . www.vintageair.com I had the guy rewire my car install the vintage air system while we had the dash out and it fit in behind the glove box barely.
The guy that I purchased the car body from had tried to fix the ac system his self and really made a wreck of all the wiring .I knew it would take hours and hours to just get the wiring right and very costly so I decided it would be best to put in system that would actually be cheaper than trying to correct the original system not to mention that now a regular mechanic can now service my ac system since it now Jaguar specific if that ever comes up in the future.
I hope this helps
I hope this helps
Great job. The XJS is a much better base to build a resto mod than an early Ford Falcon, for example. No disrespect intended, I like an early Falcons! The LS has proven to be good fit in the XJS and is easier to maintain. I also would like to see some in progress photos of the a/c installation. Thanks.
