1983 XJS v12 to Cummins build
Old 10-02-2017, 11:42 AM
Jonathan-W's Avatar
Originally Posted by Pud
Well that was the idea, but i went a little overboard today and decided to DELETE EVERYTHING! hahah
the OMG was for I have never seen an XJS so Naked...
  #122
Old 10-03-2017, 12:00 PM
Pud's Avatar
Pud
Pud is offline
I wonder if it's legal to run no wipers in Jersey...
  #123
Old 10-03-2017, 07:51 PM
Ranchero50's Avatar
Jersey drivers don't know how to use turn signals, so why not.
  #124
Old 10-03-2017, 10:47 PM
89 Jacobra's Avatar
Received 1,181 Likes on 685 Posts
I believe it's mandatory in all states to have some type of functioning wipers. That being said, a hand operated wiper, I believe is acceptable. I've seen several old hot rods and some British cars that had a single blade on the outside, with a handle on the inside of the windshield to be manually operated. I do believe that is all you have to have. I could be wrong??? But I don't think so. Ask the friendly Policeman and ask him to look up the statute, on it.
89 Jacobra
  #125
Old 10-06-2017, 10:09 PM
Pud's Avatar
Pud
Pud is offline
Update!
Unfortunately the linkage on my engine crane piston took a dump, so i got a new 8 ton piston coming in the mail. The whole crane cost me 100$ and was used so im not too miffed about it.
Anyway! Notched the firewall and now the cummins is closer than ever to fitting properly with enough room for belts/radiators/intercooler/fun stuff
Going to go with some rubber lines temporarily going to a dual pass trans cooler until i find someone to make legit 1/2" lines.
triple disc converter came in the mail
waiting on my front crank seal and rear pickup tube to come in so i can test the engine again.
  #126
Old 10-06-2017, 10:16 PM
89 Jacobra's Avatar
I can see the crazy in your eyes!!! But that's a good thing! Way to go, you may make this work yet!
89 Jacobra
  #127
Old 10-08-2017, 10:46 PM
Pud's Avatar
Pud
Pud is offline
Haha thanks man
  #128
Old 10-09-2017, 09:15 PM
Pud's Avatar
Pud
Pud is offline
Bump with a small update.
Removed the battery holder due to tiny *** battery size and needing to make it bigger for the bigger motor / more amps needed for the starter to overcome the extreme compression of the cummins.
Removed the little sump tank under the battery. Going to just use the large tank for a bit to see how it does.
BEST NEWS EVER --- - -- ~~~~
The main gas tank had nothing in it at all, but the sump tank was full of horrible old bronze colored gas. Smelled horrible. Purged it and removed the entire thing. Removed the sending unit because it was rusty but clean diesel came out of the main tank when i ran it through
Removed the baffle on the filler neck so i can fill up easier
  #129
Old 10-10-2017, 01:21 AM
Greg in France's Avatar
Received 9,300 Likes on 5,462 Posts
Why not keep the sump tank Pud? It is pretty important to ensure the pump keeps a proper supply on long fast bends!
  #130
Old 10-10-2017, 02:47 AM
Daim's Avatar
Received 2,181 Likes on 1,584 Posts
I assume he'll be using an intank pump as well as the high pressure pump on the engine. So an intank pump would eliminate the need for the little sump tank...
  #131
Old 10-10-2017, 03:41 AM
Pud's Avatar
Pud
Pud is offline
The lift pump on the engine pulls fuel from the tank. I don't need any pumps in the rear from the advice I've been getting on the diesel forums. The sump tank is extremely rusty as well. I question the inside of it.
  #132
Old 10-10-2017, 01:31 PM
Paul_59's Avatar
Banned
Originally Posted by ronbros
almost no one here know what a Cummins 5.9L ,12 valve can do,
make over 800HP BUT over 1500 ftlb. torque, without revin into hi rpm numbers.
I know you're a diesel engine fan Ron, however my information on Cummins 5.9L 12 valve engine is that the most powerful version they produced made 235 bhp 460 ft lbs as standard in turbocharged form.
Are you saying that they can be modified to get over three times the power and torque ?
  #133
Old 10-10-2017, 01:43 PM
Pud
I did not mean you need a pump at the rear. I meant that, as the main tank is very wide, the fuel sloshes to one side on cornering and the main tank central fuel exit pipe gets exposed to air and the fuel pressure drops, with the possibility your diesel injectors get air in them. The sump tank makes a good collection point that is always full of fuel. No reason it cannot be piped directly from there to the engine pump, without needing a pump in the boot (trunk).
Greg
  #134
Old 10-10-2017, 09:13 PM
Pud's Avatar
Pud
Pud is offline
I'll try to salvage the sump tank then
  #135
Old 10-10-2017, 09:48 PM
Pud's Avatar
Pud
Pud is offline
SO CLOSE.
Need to rip open the trans tunnel a bit more.
  #136
Old 10-11-2017, 08:33 AM
Ranchero50's Avatar
What's fighting with the oil pan? You have a ton of room up front, why not use some of it?
  #137
Old 10-11-2017, 09:28 AM
Pud's Avatar
Pud
Pud is offline
The trans tunnel is too narrow for the 47rh.
I want room up front for hoses, rad, fan, and intercooler. Probs trans cooler too
  #138
Old 10-13-2017, 07:09 PM
Pud's Avatar
Pud
Pud is offline
Bump. Sealed my front timing cover and my front main seal today.
  #139
Old 10-13-2017, 11:26 PM
89 Jacobra's Avatar
Boy Pud I sure wish you were closer. I just found out when my XJs had the engine fire it also burnt everything under my dash! You can't tell it from the outside but I was going to pull the interior, as I need to do some cutting to clear the headers, and didn't want to set it a fire! To late, it's already toast! So now I'm looking for a Parts car. Damn the Luck.
  #140
Old 10-15-2017, 02:37 PM
Pud's Avatar
Pud
Pud is offline
Having issues with transmission clearance still. going to be sawzawlling a lot more once i get more time... wish i had a garage haha
