1983 XJS v12 to Cummins build
Old 10-16-2017, 11:57 AM
ronbros's Avatar
Received 1,236 Likes on 943 Posts
yeah! starting to get cold up there.
  #142
Old 10-28-2017, 10:56 PM
Pud's Avatar
Pud
Pud is offline
update on jag build. Got the motor mounts welded in. Buying a new starter to test run the motor while it's out of the car and brought the trans to Aamco to have some barb fittings installed on the cooler lines so i can run custom lines to a custom cooler set up.
installed turbo
It's slowly coming along.
  #143
Old 11-03-2017, 10:16 PM
Pud's Avatar
Pud
Pud is offline
Update
whilst moving metal to make room for el cummins / 47rh i cut through a brake line
the brake line from the master to the rear fitting
luckily.. i managed to fix that. pain in the ***
bled whole system of what looked like gravy. all new synthetic dot 3 to all 4 rotors!
couldn't get the cummins to turn over properly so im bringing it to a diesel specialist nearby :/
Got the new motor mounting area welded in!
  #144
Old 11-03-2017, 10:29 PM
Pud's Avatar
Pud
Pud is offline
89 Jacobra (11-04-2017)
  #145
Old 11-04-2017, 12:16 AM
89 Jacobra's Avatar
Received 1,213 Likes on 700 Posts
Wow I wondered what was behind all the sheet metal! You made a real, damn big hole! I'm going to have issues with the areas just outside where you've cut as My headers swell out to the sides before they come in toward the block and go down through the engine compartment. I don't think I need as big a hole as you've made but I'm going to have to do some Surgery! Thanks for the pics.
  #146
Old 11-04-2017, 12:25 PM
Pud's Avatar
Pud
Pud is offline
im going to patch a bunch of it up eventually. The trans sits much higher than i thought it would.
  #147
Old 11-05-2017, 05:15 AM
Daim's Avatar
Received 2,181 Likes on 1,584 Posts
Pud, whils you're at it, could you shoot me a picture of the drainage pipes? Basically from the side showing the wiper box area (looks double layered?) and how and what angle the pipes come out at?
Cheers! Mine have rotted and some pictures would help the guy welding them.
  #148
Old 12-16-2017, 05:44 PM
Pud's Avatar
Pud
Pud is offline
Those two openins in front of the big cut out are where the drain pipes used to go.
Bump! The jummins motor is alive! NJDRP reset the bottom end and it came to life!
~$700.75 later
  #149
Old 12-16-2017, 09:19 PM
89 Jacobra's Avatar
Ouch! thank God it wasn't more then that. Sucks but now on to the Fun!!! IT RUNS!!! way to go Pud.
Jack
  #150
Old 01-31-2018, 03:29 PM
jagwarman's Avatar
Hi, I have actually seen someone put a 12 valve cummins in a XJS. So it can be done. I run a 12 valve cummins in my 94 dodge 1 ton a great engine with low horsepower but tons of torque. He didn't get a fast off the line car but it cruises at 90mph at 2000 rpm's because of the 2:88 gears in the Jag. But it is horribly nose heavy . Have lots of fun with your project. The second gen cummins has a better style injection pump. from the color of your engine I would say it is a 185 hp engine not from a pickup.
ronbros (02-01-2018)
  #151
Old 02-17-2018, 04:39 PM
Pud's Avatar
Pud
Pud is offline
Damn, didnt know someone else beat me to the punch.
I knew it was the first gen cummins, and i know about the better p pump
Anyway, small update! Managed to cop a big turbo off of a cat engine in a local junk yard. Excited to say the least. Engine is still at NJDRP for storage. cant work in the cold weather right now
89 Jacobra (02-17-2018)
  #152
Old 02-18-2018, 10:36 AM
JagCad's Avatar
Received 2,399 Likes on 1,880 Posts
My son has a 95 Dodge 4x4 powered by the Cummins. It has pulled some really bog loads. Many, many miles. Still plenty of power. Manual transmission. Son says better than the Allison autobox found in many.
Way back when a Cummins powered car raced at Indy. A local guy drove it. didn't win, though.
Carl
  #153
Old 02-20-2018, 08:55 PM
Pud's Avatar
Pud
Pud is offline
Junkyard turbo + rehab
  #154
Old 02-20-2018, 11:21 PM
89 Jacobra's Avatar
You got the right Idea, More air, and More fuel, = More Horsepower!
  #155
Old 06-09-2019, 06:34 AM
Addicted2boost's Avatar
Received 1,139 Likes on 870 Posts
Updates???
  #156
Old 06-09-2019, 03:18 PM
icsamerica's Avatar
Received 1,378 Likes on 804 Posts
Originally Posted by Addicted2boost
Updates???
I think this project was forsaken. I saw the parts being sold off on craigslist a while ago. Revist post 10 on this thread...that will explain some of it.
  #157
Old 06-09-2019, 09:35 PM
89 Jacobra's Avatar
Yes as I remember soon after his last posting. He got tangled into a Divorce, and was trying to sell it all off very cheap. I think he was having to move, and had no where to store it. I know there is another thread on it somewhere.
jack
  #158
Old 06-10-2019, 06:19 AM
I wonder if hearing about someone else having done the same conversion pretty much set him back on the project? That and a divorce would certainly spell the end of it too I suppose.
