1984 Jaguar xjs v12 just purchased
Just last week I purchased a 1984 Jaguar xjs with a V12. Everything was working properly, power windows, wipers, wiper washers, blower motor, horn and there may be a few more things that aren't working right.
I didn't dig into it yet but I took the fuse box cover off and the fuse panel looks perfect, but of course I will check all the fuses tomorrow. Is there a specific relay that anyone knows about that could be causing the main problem because I cannot believe that all of these fuses blew simultaneously.
any help would be appreciated
Welcome to the Forums.
I do not know of a relay for all that on an 84 car. Later years, yes.
BUT
You are UP HERE, and your market called for some weird stuff at times. Members in your market will know 100%.
Sometthing has shorted, and you will spend many hours/days/weeks maybe, going through each circuit quietlyu and systematically.
I always suspect aftermarket items, alarms, imobilisers, etc. so if these are fitted, REMOVE THEM, get the wiring back to Factory spec, and begin from there. These are SIMPLE cars in the true meaning of that phrase.
BUT
BruceCarlo (07-23-2023),
JJS- Florida (07-23-2023)
Received 10,979 Likes
There is a "Load Relay" on the left component panel under the dash. It powers-up 3 or 4 fused circuits. Might be worth checking. For identification, it has brown, black, and white/pink wires
The following 3 users liked this post by Doug:
The following 3 users liked this post by jal1234:
Wiring diagrams are here:
JagRepair.com - Jaguar Repair Information Resource
