1985 XJS
Guest
Posts: n/a
1985 XJS
G'Day, I'm new to this so please bear with me. I have a 1985 XJS that hasn't been used for a while and had a flat battery. A friend was helping me get it started, with a jump start, and inadvertantly conected the wrong terminals (Bad mistake).
It now wont start, and I've checked all fuses, and fuseable links, and everything seemes OK, I've also changed the I.C.U.
With the ignition on , I am getting power to the coil (only 11.8 Volts), but no spark at the plugs.
Have checked the Ignition Amplifier Module and it has no power out, could anyone give any other suggestions, or is the I. A. Module stuffed.
Thanks Murrumbung2
Thanks Murrumbung2
Guest
Posts: n/a
