1985 XJS Blower Speed Problems
Old 01-05-2020, 04:20 PM
sanchez's Avatar
Doug: A couple years ago when I had problems with the series 3, you had recommended to me to jump the grey connectors as part of the diagnostic process. The resolution then, was a bad main relay.(I have to see if the 85 XJS has the 2 grey connectors).
Subsequently, during the summer of 2019 I had a situation where the AC system would not turn 'on' and that was resolved with the replacement of the Mode switch which I acquired from EVERYDAYXJ.
In the next week or so I will have a main relay, amp, mode and temp switches (all of which are "KNOWN GOOD") in my hands so I can sub the parts as I proceed with the diagnostics.
Will keep everyone in the loop as I go along.
@Grant: I hope I don't have to go behind the instrument cluster. 3 weeks ago I had it out to get all of the lights working and ended up having to do a lot of soldering back there because there were some broken bits.(Lots of brittle stuff behind the cluster).
I ended up having to (very gently) replace the instrument cluster and it functions as it should now.
The following 2 users liked this post by sanchez:
Grant Francis (01-05-2020), Greg in France (01-06-2020)
Old 01-10-2020, 06:34 AM
sanchez's Avatar
Thank you all for your inputs.
Blower motor issue resolved: Faulty Mode Switch. Replaced Mode Switch and all is well.
During the process I disconnected and cleaned every connector I touched.
Now on to putting everything back together again.
Doug (01-10-2020), Greg in France (01-10-2020)
muttony
08-21-2022 06:59 AM
jordanmc
11-11-2017 09:18 AM
jordanmc
04-14-2017 08:44 PM
davesafoothill
01-19-2015 12:05 PM
Donzi
09-20-2013 05:04 PM
Quick Reply: 1985 XJS Blower Speed Problems
