1986 XJS V12 Alternator Problems...Help!
3 weeks ago my alternator bearing locked up and the lightning bolt and dash light came on, along with my voltmeter dropped into discharge. I had my mechanic replace it with a NAPA rebuilt. I also installed a new OEM battery. Although the new alternator charged, it was difficult to excite and even with the engine off and key removed, the lightning bolt and warning light came on? I installed a battery cutoff switch to prevent drain overnight. Progressively over 2 weeks the voltmeter showed erratic charging and difficulty in exciting ( had to rev it up) Today my voltage began dropping into red discharge, alternator will not excite. Belt is good. Bottom line, did I get a faulty alternator with bad diodes? I would appreciate input before I spend two hours uninstalling and returning the unit under warranty. Oh...I did check voltage at battery with a meter. 11.7 volts not running, same running.
Received 10,872 Likes
15 years ago, I went through this with another XJS-C that I owned. If I recall I went through 3 bad rebuilt alternators in 5 weeks. It drove my mechanic crazy. 15 years later, the same bullshit....Junk alternators allegedly rebuilt and tested bought at NAPA. More crap from Mexico. Frustrating since it's gonna cost me for labor to swap out! I wish I could find a brand new one.
Fully discharged battery @12V? I guess I would like this kind of fully discharged battery... ![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
My battery is not a spring chicken, but it gets to 11.7V-11.8V range after sitting in a garage for 2-3 days not driving. The engine starts from 11.7V. It can even start from 11.6V. If it drops below that, it requires connecting external charger
The battery must be disconnected to measure it otherwise the reading will be I would suggest what you measuring the battery with is incorrect .
v1rok (05-19-2017)
Not to take the thread off topic, thank you, warrjon, for the link. Good point about measuring the voltage with everything completely disconnected.
Received 2,399 Likes
1. Curious me. Why would there be any difference in available volts at the battery posts, whether disconnected ort not? So, long as the probes are on the posts and not the clamps? Rules out poor connections, either way?
2. I made connector for my VOM. Wires to a device that inserts into the cigar lighter.
I can read volts in real time, under various rpm's and loads.
3. Rebuilds have suffered badly in quality. I do recall, decades back visiting a high volumn rebuild shop. Not reassuring at all. A bit like not destroying ones appetite for sausage by visiting a sausage factory. I suspect many are merely a reassembly of parts of failed units that still "'work"!!! The days of rewinding coils and armatures
probably long gone....
Carl
Carl
Carl
Carl
Which is why I began using a local rebuilder several years ago. 100% success rate versus 50% success rate with off-the-shelf rebuilt units.
Most cities and towns, it seems, have a local shop doing starter and alternator overhauls
Greg in France (05-20-2017)
Of course it's good practice, just on general principles, to check all relevant connections and wires. Doubly good practice on old Jags.
Some years ago I helped a pal with charging problems on his XJ6. Long story short, the output wire from the alternator was badly corroded under the insulation. Very high resistance.
The reason is, any current draw on the battery will cause a voltage drop and the difference between a full and discharged battery is less than 1volt. Disconnecting the battery removes this unknown.
JagCad (05-24-2017)
My other cars including Triumphs, Austin Healey, MG, Lotus, Sunbeam, Maserati, Bmw, and other numerous American cars and trucks...never had alternator issues. Only my Jaguar XJS cars....
Lucky you!
I've generally had good luck with alternators.....with the notable exception of the GM cars I've owned. But that's another story.
But, even then, when dealing with rebuilt anything, the onus shifts mostly to the rebuilder rather than the type of car.
You might wanna do some digging to see if there's a underlying issue with the car....some sort of wiring fault possibly. Also check that the alternator bracket is well grounded. The engine grounding wasn't very good on these cars. I ran a redundant ground cable to the engine on mine
Update: Swapped out the 3 week old alternator with a warranty replacement from NAPA today. It's now throwing a charge but now my lightning bolt fault light is illuminated! What the hells up now? If you recall these lights were coming on with the ignition off and key removed. My battery was down to 9 volts when swapping the alternator. Battery is brand new, and alternator is not Lucas,but upgraded type. Any ideas what's happened?
The lightning bolt will light in 1 of 2 scenarios.
1 if the Alternator voltage is higher than the battery
2 if the battery voltage is higher than the alternator
If your battery was down to 9volts this is the reason for the light. Once the battery is charged the light should go out as long as the battery is not damaged.
Lead acid batteries do not like being discharged to this low level and it damages the plates and/or dries out the acid. In a sealed battery low acid level will almost invariably mean the battery needs to be replaced.
