1988 full throttle switch
I am sorting out a "garage find" early 1988 coupe.
No matter how I try I can't get the full throttle micro switch to adjust. I have tried 3 switches including the Jaguar part.
There is just no runout or cam action to the turntable surface...........has someone installed an earlier turntable on this car? It almost looks like the turntable is off 180* because there is a big flat spot on the other side.
Thanks!!
Thanks!!
For others who might have the same problem, here are some pictures of how the capstan should be oriented (throttle closed);
![](https://cimg8.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/900x601/capstan1_1461e19549b0a5944775d793ddc8c23795da42cd.jpg)
![](https://cimg9.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/900x734/capstan2_7a16d26bee29dfb33f17d3aca59856e0395bfe11.jpg)
Mark
The following 2 users liked this post by Safari:
EcbJag (05-08-2015),
Greg in France (05-21-2017)
Guys I am replacing both my kick down and full throttle microswitches on 1988 XJS H&E. however the original microswitches have two pins and the new switches I got have 3. why and how are they supposed to be connected? Did I get wrong switches or am I missing wires here(I don't think so) Help is appreciates
Greg in France (05-22-2017)
The three terminal switch has two states, state 1 where the switch is closed (circuit completed) and state 2 (open circuit) when the switch is in the other position.
Attached are photos of my three-position switch wiring. Both the kick-down and full-throttle positions work as expected on my car. What I can't say if if you switches are configured the same way, so it's a good idea to meter them out. My car is an '87.
It might be a bit hard to tell in the second photo, but I'm hooked up to the center terminal and the terminal that is closest to the passenger compartment.
Thanks,
John
19887 XJ-S V12
Thanks,
John
19887 XJ-S V12
Thanks!!
Thanks!!
Aus V8S
11-13-2015 11:01 AM
xjrjag
09-27-2015 01:53 AM
