1988 Jaguar XJS Radio
Radio stopped working. I change the fuse in the radio (10 amps) and another one below the glove compartment , and still no luck, Is there other fuse i need to check ? Someone told me to check the radio relay. Where is the radio relay located at at what is it look like ? How will i know that my radio is already done. Anyway to check the harnesses ?
I don't know what that is. IIRC, there is no blue wire in the radio circuit.
It looks like someone 'fixed' something, so you have some work to do to figure out how the circuit is supposed to be. You should download the schematic so you know what is what:
http://www.jagrepair.com/images/Elec...Electrical.pdf
Good luck
Good luck
orangeblossom
03-30-2014 05:29 PM
1985TVR
11-04-2009 11:10 PM
jaguarxjs
10-18-2009 11:39 PM
killerbracing
06-08-2008 02:17 PM
