1988 xjs coupe-will not start
Yes, makes sense. The engine computer is very picky about the sensor inputs and can do some odd things when they're wrong. Interestingly, not everyone gets a no-start condition when the coolant temp sensor isn't hooked up or is bad but it does cause assorted issues.
This guy has some good info - this link is specific to the CTS (coolant temp sensor).
Sean's Jaguar Tech Pages - A Coolant Temperature Sensor Emergency Switch
This is probably related to your idle issue thread.
jomia092306 (03-25-2014)
...Hello All...i got my car started today...i followed your advice, chk the fire triangle ...and then check all the wire. I noticed that one of the wire is cut. this wire is going to the thermostat control sensor. As soon as I fixed this(wrap an electrical tape around it)...the car starts...does it make any sense? I will check all my wiring tomorrow to make sure that nothing is cut or expose.
Just read that bit about the temp sensor, you learn something new about these cars everyday, must note that one in the book for further reference.
Cheers and good luck to you.
That makes sense, although I can't imagine what cut it. I had a bad connection to the temp sensor, and my car wouldn't start very easily. The ECU uses that signal to enrichen/lean the fuel mixture. With no resistance whatsoever, I could see the ECU not sending a fuel signal at all to the injectors.
Do you have a digital volt meter? You can test the sensor and the harness easy enough. The resistance values are listed in the ROM. I can send them to you if you don't have them. If this is your problem, you just unplug the sensor, test the resistance value and if it is in range, it isn't the problem. You plug it back in, go back to the ECU, unplug it, and check the resistance values at pins 1 and 5 on my car (I think) and see if they are the same. If not, you start back tracking until you find the problem.
Someone post a quote that says something about replacing parts seldom being effective, but almost always expensive.
Wolfy
05-28-2024 08:06 AM
Jaguar Forums Editor
Jaguar Press release
09-03-2015 09:38 AM
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
09-02-2015 11:43 AM
