1989 5.3 V12 power steering fluid leak
dont forget the pump
put a large bit af flat cardboard under the car, and turn over the engine, if its leaking that much i would turn it of right away , look at the cardboard and it will give you a clue to where the leak is
the hoses are prone to wear and or cuts, the unions can go but are more robust, the pump seal can go ,
but as above , you need to identify the leak first
on the V12 there is a cooler mounted on the front subframe on the left of the engine bay b the engine mount, they can rot out to ,
BB
BB
rusty37
04-05-2020 07:40 PM
Dicque
09-19-2015 12:53 PM
