1989 abs distribution block pin out
Old 10-16-2012, 11:30 AM
wesmc2's Avatar
Default 1989 abs distribution block pin out
Anyone have a pinout for this? As in my earlier post when I disconnect lines under at the master cyl/distrubution block I have fluid to rears and right front.
It seems I have a bad solenoid in there (LF) but I cannot tell for sure. I would like to build a test rig (since this unit is crazy expensive)but don't know which pins are signal, voltage, or ground.
Old 10-16-2012, 04:58 PM
Per's Avatar
Per
Per is offline
You could try a valve block from same period Buick, take the block to a scrapyard and compare. If you want the wiring diagram with pinout send me your email by PM.
Dave1109971
12-15-2015 06:16 PM
goges
10-05-2015 04:53 PM
leep123
09-30-2015 03:41 PM
mrplow58
09-30-2015 08:56 AM
Quick Reply: 1989 abs distribution block pin out
