1989 XJ-S 5.3 Engine Stopped
My Engine suddenly stopped while driving last week. I called the AA and the mechanic thought that I had put in diesil fuel as I had filled up 15 minutes before. I emptied the fuel and filled up with unleaded and no joy. I have a marelli digital ignition system. I have renewed The two Sensors,two coils,ignition leads,distributer cap,rotor-arm,spark plugs. I have a new fuel pump and filter and they are working ok. The car was running perfectly until this happened. Is there a way to find out if the Injectors are working as they have not been renewed. Is there a Relay or Fuse that would cause the Engine to stop dead??
I am at a loss as the nearest Jaguar Garage to me is 30 miles. The AA said they would drop the car off for me but I declined as you know what Jaguar could charge. What tests can I try Now??
Mmmmm, on the 2 Marelli beast I contact from time to time, one had the same.
Look (hahaha) down the front of the engine, sorta below the oil filler cap, and you will see a small wire loom with a plug connector/joiner. Unplug it, clean the contacts, and see what gives. It is the front crank sensor loom, and that dumb thing killed one car twice, the first time was a challenge to locate the cause, the second was simple obviously.
I cannot see the relation to filling with fuel, but who knows.
I bought a new Coolant temp sensor and installed it yesterday. I also checked both the Flywheel and Crankshaft Sensors (new 1 month ago) and got a reading of approx 660 ohms each. She is turning file and giving a spark but just not firing. I used the fuel pump to empty the fuel into cans and the pump seems to be working fine. I emptied 30 litres of fuel pretty quickly. The pump and filter are only three months old. Maybe it is a problem with the Injectors? I gave up yesterday. I have had enough for a day or two. It is diffucult to get hold of an auto engineer who knows anything about the xjs, even at the Jaguar Garage.
60dodgecars (07-02-2012)
Your "94 XJ6 is known as an XJ40, so I would strongly suggest reposting this in the XJ40 area, so you get the best, most accurate assistance for your specific car. The XJ-S V12 is very different.
60dodgecars (07-04-2012)
scottatl
09-04-2015 08:08 PM
1989, cap, check, coolant, distributer, distributor, ignition, jag, jaguar, marelli, sensor, stop, temperature, xjs, year
