1989 XJS marelli distributor rotor
1989 Jaguar XJS with Marelli ignition.
Can the distributor rotor only be installed one way?
In the process of swapping spark plugs I rotated the engine with the rotor removed and lost the placement of rotor on shaft.
(I got distracted after removing the rotor, dealing with two seized plugs that required an easy out to remove).
Thanks!
Andy
Thanks!
Andy
Please correct me if I am wrong but I think it would be very difficult to install the rotor incorrectly.
If you look at the photos below you will notice that the screw holes on the rotor and distributor are not on the same centerline. One of the holes is slightly off center.
I'm pretty sure the offset is there to insure proper rotor alignment.
Mark
Mark
vinny jones
10-05-2015 07:20 AM
