1989 XJS radio code AM/FM Cassette
Check to see if someone has written the code on the radio itself with a marker pen, I've found that more than a few times when I've had them out.
Have you looked through any paperwork you may have?
Another place is on the back or underside of the ashtray.
If no luck, there are programs you can download that will read the radio code for you or clear it altogether.
Lucielle (10-15-2022)
Is that the type of radio that has solder pads under the sticker? If so, take a look here for more of radio codes and how you can change the code. See towards the bottom of the thread and the second page.
https://www.jaguarforums.com/forum/x...io-code-35298/
