1989 XJS V12: Fuel Injector Hose Clamps
Received 10,872 Likes
I wouldn't use clamps, personally. The risk is that clamping the hoses will cut them, as the barbs on the nipples are very sharp. For ferrules, try Dave at :
Jaguar Fuel Injector Service
And/or search the archives ("fuel hose ferrule") for other sources. They're not really Jaguar-specific
Thorsen (01-03-2022)
Some guys do use clamps, yes. There's no particular reason to use them, though, except perhaps a feel good thing....which I understand. If you do use clamps it really doesn't matter if they're heavy duty or light duty or anything else, as the nipple design doesn't require them in the first place ! Once you press that hose on, it ain't comin' off for love nor money!
Greg in France (01-04-2022)
Not really Doug, barbed fittings can leak under pressure. That's why hose clamps exists. Yes they should be fine under normal circumstaces but who plans for the norm when you deal with gasoline? We could probably go back and forth on this but it's pointless. You'll tell me that there's no problems and I'll point out plenty of V12 jags that have burned to the ground.
