1990 Jaguar XJS - No Lights on Dash, No Crank, Dead-ish
Old 04-22-2022, 09:43 AM
JayJagJay's Avatar
Received 1,296 Likes on 897 Posts
Originally Posted by orangeblossom
Hi Jay
Well done! you may even have to show me how to do this one day!
Meantime why not try Hot Melt Glue that can be cut through with a Craft Knife if you need to get it apart at any time
Well done again!
Alex
Hey Alex. Thanks!
Hot glue... I like it. Not like epoxy (or something) which is harder and permanent. It is very likely I will have to be back at this thing considering it's condition after my barbarism at some point in the future. So anything "fix" has to be serviceable...
Thing is, hot glue would mean opening it again,,, and for reasons - well the whole thing/operation is pretty scary... Replacement cost can be high and for the 1990 I haven't seen any used on line. I think they are rare. All it would take is loosing a (super small) spring or completely cracking something,,,, I dunno
I was thinking, first, maybe I would try 2 zip ties,,, and then see the effect that would have on the seating of the unit against the wheel and the rotational PIN that comes thru the tumbler that actually turns the innerdz of the switch.
The wear & malformation of the plastic slot on the column facing side of the switch is the reason for all of the SLOP in my ignition key. Don't quite know if there is anything I can do about that either... This ol thing!
Old 04-22-2022, 09:54 AM
JayJagJay's Avatar
I've never looked closely at this before.
this is a pretty valuable schematic...
Old 04-22-2022, 11:28 AM
orangeblossom's Avatar
Received 3,771 Likes on 2,611 Posts
Hi Jay
Run a Ring of Hot Melt Glue around the Join on the Outside
So no need to take it apart to do that
Good Luck
Alex
Greg in France (04-22-2022)
Old 04-22-2022, 12:40 PM
JayJagJay's Avatar
I'll give it a shot! Thanks OB!
Old 04-23-2022, 06:44 PM
JayJagJay's Avatar
Really, I cannot believe it....
The entire time I've had this car the VOLT meter has run below 13v, well below in some cases. I thought that it was old and lazy, not functioning properly.
Today it runs above 13v, at the tiny line between the R and the M in "normal" on the gauge - and I can't pin point exactly what it is BUT,,, the car has a whole new life to it... Ya just DON'T know what ya DON'T know... And that's putting it mildly.
Thank you all for taking the time to think about this issue with me... Really!
ps... Grant,,, I was only joking - ya must know it...?
And a strong suggestion, as pointed out in the write-up for re-habing the switch (as I did thanks to Grant) OPEN THE SWITCH IN A LARGE SEE THRU ZIPLOCK BAG... It will save you from crawling around on the floor cursing and swearing looking for micro BITS, lol. It's a super right suggestion.
The following 2 users liked this post by JayJagJay:
Greg in France (04-24-2022), orangeblossom (04-23-2022)
jamesholland
04-01-2021 09:35 PM
dazer2000
05-08-2015 12:58 PM
dazer2000
05-08-2015 02:39 AM
5tevie
03-26-2012 06:41 AM
Quick Reply: 1990 Jaguar XJS - No Lights on Dash, No Crank, Dead-ish
