1990 V12 Diagnostics
I have an EPROM in my ECU, I took it out and pulled the code from it and found a serial handler.
There is a three-pin header on the PCB that is connected to the serial port that can be used to communicate with the processor, it doesn't come to the outside world. It is obviously something that Lucas used to test the ECU on their assembly line.
