1990 xjs 3.6 non starter - URGENT
i recently purchased a new battery after the last one failed. i have been using the car regularly since the new one has been fitted. yesterday evening the car would not start.
when turning the key to ignition position a click can be heard at the front left of the car. i believe this to be the starter relay. and nothing else happens.
can anyone please suggest some possible fixes?
the car can be parked where it is until tomorrow evening...
The following 2 users liked this post by Brake buster:
orangeblossom (02-03-2021),
ptjs1 (01-28-2021)
You can get 12v to a starter, but not enough amps, or good enough ground for the amperage to flow thru the starter and back to body ground, thru to the battery. I would check major ground points, yes the ground strap and at the battery itself,,, where the neg cable bolts to the car.
Have you run a 2nd dedicated ground from the engine (bolted to the alternator fastings, to the body? Hard second ground point from the engine block to the body.
I had similar issue and power wasn't really coming to starter because the nut that connects thick cable from starter to rail (one below windshield and covered with plastic/rubber) was loose.
To 'debug' :-)
1. connect control lamp to the top contact on starter (on the top of solenoid) - it should be 'on' . What happens when you click the starter? if it goes off - you don't really have enough power coming to starter.
2. connect control lamp to the bottom contact of starter (on the bottom of solenoid) - it should be off. What happens when you click the starter? If it stays off - solenoid is bad. If it turns on - starter/brushes bad.
Here I assumed the click is from solenoid on the starter. If it is not - you need to trace signal to the solenoid control wire, the one on the side between 'top' and 'bottom' contacts. If you connect control lamp to that one(with the wire that is already there) - it should come 'on' when you turn the key and stay on when solenoid makes a 'notable' click.
To 'debug' :-)
ptjs1 (02-04-2021)
