1990 XJS convertible antenna
If you have a poke about in the space between the exhaust tunnel and the outer skin, near the aerial, you will find a largish green relay and also a line fuse. If the fuse is OK, then it is likely that the relay is stuck closed. Either buy a new one (it is a special one so OEM is required) or, carefully prise off the green cover and you will see a couple of contacts that look like old fashioned distributor points. If you clean these up and try it, the relay may well work.
Greg
Greg
macdoesit (03-18-2016)
The following 2 users liked this post by orangeblossom:
Greg in France (03-18-2016),
Greg in France (03-19-2016)
WinterJag
03-23-2016 02:40 PM
Roger Mabry
03-12-2016 08:57 AM
