1990 xjs engine parts swap "
Old 07-07-2024, 06:55 PM
sanchez's Avatar
Default 1990 xjs engine parts swap "
STARTING NEW THREAD: I HAVE NEVER DUG SO DEEP INTO A V12 ENGINE SO I WILL NEED ADVICE:
I removed the blown engine from the car yesterday so now I have both engines side by side on engine stands. I will call the engine from the car Engine #1 and the Spare Engine #2
Before I go further, Engine 1 is a A series and Engine 2 is a B series. Engine #1 is Marelli and Engine #2 was Lucas.
THE PLAN:
Engine 2 had a dropped valve seat which damaged the head and the piston on Bank B Cyl #1
Since Engine 1 was a perfectly running car until it got destroyed after an oil change?? I want to swap some parts from Engine #1 into Engine #2
a. Remove a piston and liner from Engine #1 and install it into Engine #2. Renew all big end bearings if needed. What do I use to to seal the replacement liner? Any advice on this part of the job is welcome.
b. Remove the heads complete with Camshafts from Engine #1 and install them on Engine #2.
c. Remove damper assembly from Engine #1 and install on Engine #2
Question. Is the Marelli car's flex plate (drive plate) different from the Lucas? How does the ESS (speed sensor) read the engine RPM? Is there a special tooth on the ring gear that triggers the RPM reading? If it is the standard flex plate I will leave the one on Engine #2. If not I will swap them over.
Once the above is done, the reassembly will begin.
All new gaskets and O rings for the engine.
If any of the above is not doable please let me know.
Also, I will also want to flush out the oil cooler and lines. Is this possible or should I replace it?
Recommendations needed.
Old 07-08-2024, 01:28 AM
Greg in France's Avatar
Received 9,330 Likes on 5,475 Posts
Sanchez
Flex plate is the same on all GM400 5.3 HE engines.
Speedo drive question: Do both cars drive the speedo from the rear differential, or does the Lucas one drive it from the gearbox?
A and B for the engines just refers to the tolerances of the piston and liner set. As long as you remove the piston AND its liner and replmace it by a piston AND its liner to do the swap, all will be well. It does not matter if an engine has a mix of A and B piston/liner sets as long as each cylinder has one of the other.
Palm has stuff on the liner sealing.
PLEASE takes lots of photos and post as you go along!
The following 2 users liked this post by Greg in France:
JJS- Florida (07-08-2024), ptjs1 (07-08-2024)
Old 07-08-2024, 02:11 AM
Received 10,517 Likes on 6,947 Posts
Adding to Greg's post and my thoughts from way down here.
I am assuming both engines are USA spec engines ??
My reasons are that the Lucas engine is more than likely 11.5:1 Comp ratio.
GUT FEELING, is that the Marelli went to a lower comp ratio world wide, BUT, only a gut feeling.
That would have a lumpy running engine for sure.
SOOOOO
Paul, PTJS1, will have the answer when he wakes up and gets some coffee in him.
All the rest looks OK.
Old 07-08-2024, 06:15 AM
sanchez's Avatar
@Greg and Grant: Both engines are MY 1990 XJS' so the presumption is that both were diff driven speedos. I do not think that matters as I am bolting the tranny from Engine #1 to Engine #2.
Also, I have not looked deeply into this but do I have to replace the timing chain cover from Engine #1 to Engine #2 to facilitate the installation of the the front crank sensor?
I have a hard copy of 'Palm' so I will read up on sealing the liners.
From what I have gleaned: "Whether Lucas or Marelli, the engine blocks are the same. Series A and B blocks only denotes the variance between piston and liner which varied 0.0001. Maybe my interpretation of what I read is wrong, but the consensus is that piston and liner from either series must match. Can I remove the piston and liner as one unit or should it be separated and installed liner first then piston. One other thing to note is that the standard piston rings are the same for either A or B engines. I hope I am right. "Looking" at both engines, they look the same. Combustion chamber in the heads; piston crown flat, but I am pushing 74 so my eyes may be deceiving me. I don't know much about the comp ratios of Lucas engines compared to Marelli engines. My thought is that the names Lucas or Marelli refers to the type of ignition systems used on these engines. You all are the gurus of these engines so I have total confidence in every comment/post made by you all. RESPECT.
On another note regarding valve seats. Should I remove all the valves on the heads I am going to use to inspect the valve seats? What am I looking for? Is this just extra work?
I don't want to install heads, which I know very little about and have a valve seat drop down the road.
Should I install new piston rings or should I leave them alone. Looking to save some $$ here.
BIG ?: I have to turn the engine I am going to use with the heads off in order to remove and replace the piston and liner. Will the method I used in the attached photo suffice or do I have to put another liner hold down on the other side.
In my other post, I mentioned while removing the head from Engine #2 it stalled 1/2 to 3/4 inch up and I had to cut 4 of the inner studs in order to remove the head. I successfully removed the cut studs. I am wondering whether I should replace all the studs on the engine I am going to use or just the bad ones. What say you?
this is what I am using to prevent the liner from moving
Old 07-08-2024, 06:44 AM
Also, I have not looked deeply into this but do I have to replace the timing chain cover from Engine #1 to Engine #2 to facilitate the installation of the the front crank sensor? No idea, but take a look at see, it will be obvious.
I have a hard copy of 'Palm' so I will read up on sealing the liners. OK
From what I have gleaned: "Whether Lucas or Marelli, the engine blocks are the same. Series A and B blocks only denotes the variance between piston and liner which varied 0.0001. Maybe my interpretation of what I read is wrong, but the consensus is that piston and liner from either series must match. Can I remove the piston and liner as one unit or should it be separated and installed liner first then piston. Removing the liner may not be easy. I advise FOR SURE remove the piston first. To remove the liner you will almost certainly need to get a mchine shop to make you a puck of the same diameter as the liner O/D with a step to a reduced O/D in it that fits inside the liner I/D. Then either whack the puck to push up the liner, or make a hole in its centre for (say) 18mm threaded rod, and protecting the deck with wood, wind the liner out using a thick piece of steel across the wood blocks, threaded rod and a nut under the puck and above the steel.
One other thing to note is that the standard piston rings are the same for either A or B engines. They are.
Combustion chamber in the heads; piston crown flat, but I am pushing 74 so my eyes may be deceiving me. I don't know much about the comp ratios of Lucas engines compared to Marelli engines. USA 5.3 HE engines are all the same CR. With the introduction of the Marelli ignition, ALL V12s became 11.5:1 worldwide. Originally, up to the Marelli intro, UK and ROW had 12.5:1 CRs.
My thought is that the names Lucas or Marelli refers to the type of ignition systems used on these engines. Correct, but instaling a Marelli ignition engine in a Lucas wired car may not be simple, as Marelli has an extra ECU to handle the ignition as well as the boot installed ECU. As long as you install a Marelli engine into a Marelli-wired car, no problem.
On another note regarding valve seats. Should I remove all the valves on the heads I am going to use to inspect the valve seats? What am I looking for? Is this just extra work? Leave well alone!
Should I install new piston rings or should I leave them alone. Looking to save some $$ here. No need for new rings. The bores will almost certainly be fine and likely still have the factory hone hatching on them. Only if the bores are scored, OR if a huge wear-step at the bore tops above the ring max point need you do anything.
BIG ?: I have to turn the engine I am going to use with the heads off in order to remove and replace the piston and liner. Will the method I used in the attached photo suffice or do I have to put another liner hold down on the other side. I would do both sides for safety!
In my other post, I mentioned while removing the head from Engine #2 it stalled 1/2 to 3/4 inch up and I had to cut 4 of the inner studs in order to remove the head. I successfully removed the cut studs. I am wondering whether I should replace all the studs on the engine I am going to use or just the bad ones. What say you? Replace any badly corroded/eroded stud, if they are OK no need to unless you are going to race the car!
I would decoke those piston tops! That is the dirtiest-looking piston top I have ever seen in a V12! What are the bores like, they should be coke free below the piston rings max height?
The following 3 users liked this post by Greg in France:
Grant Francis (07-09-2024), JJS- Florida (07-09-2024), ptjs1 (07-08-2024)
Old 07-08-2024, 07:03 AM
For general interest, the relevant extract from AJ6 Engineering's old website:
"European flat head V12s had 9:1 compression ratio and US emission versions had 7.8:1 but the star was the 10:1 compression version made for just one year from mid-1980. HE V12s were normally 12.5:1 compression or 11.5:1 for emission versions and all Marelli 5.3 engines.
The 6 litre ran at 11:1 compression. For those who are interested there are some typical V12 power and torque curves in the 'V12 Archives' section."
https://www.jagweb.com/aj6eng/v12_performance.php
Mguar (07-10-2024)
Old 07-08-2024, 07:41 AM
sanchez's Avatar
Greg. The cylinder bores are in good condition. I will "decoke' the pistons before reassembly. I will be attempting to remove the head studs that I need from Engine #1 to install in Engine #2.
I have a stud extractor which I successfully used to remove the 4 cut studs. I don't know of the stud extractor I used will damage the threads on the studs. I will try the 2-nut method first.
The following 2 users liked this post by sanchez:
Greg in France (07-08-2024), JJS- Florida (07-09-2024)
Old 07-08-2024, 07:47 AM
ptjs1's Avatar
Received 3,094 Likes on 2,042 Posts
SOOOOO
3rd coffee in, but I see that Greg has already done all the heavy lifting on the answers, particularly the compression ratios!
I'll bow to Kirby's statement on the .0001 difference on A & B pistons & liners, although that does seem a very fine tolerance? Everything I've read has always indicated that you must match pistons and liners. However, you really need to measure everything as you don't know if anything's been previously changed, so the A/B indicator may not be accurate for the engine in it's current state. Also the SA / SB indication for compression & piston size is APPARENTLY only relevant up to engine 8S72157, so check the engine block numbers.
As Greg has mentioned, I think installing a full Marelli engine configuration in a Lucas car would be more difficult than the reverse.
Good luck, and keep the pics coming!
Paul
The following 2 users liked this post by ptjs1:
Grant Francis (07-09-2024), Greg in France (07-08-2024)
Old 07-08-2024, 08:57 AM
Paul
Interesting point about liners. I actually have a B engine in my car, and against a possible engine rebuild as a prophilactic against boredom in advanced old age when Madame will no longer let me drive, I have four genuine NOS B spec liners in stock together with everything else needed including new rods, heads, tappet blocks, valves and springs; all genuine parts.
AS i was concerned about perhaps needing more liners, I bought some more new ones made by the same firm that made the Jaguar stocks. They only supplied A spec so i sent them to the top guys in Coventry to be sized to B. Having measure them all, they were ALL at least big enough diameter-wise to qualify as B spec! So no work needed!
Grant Francis (07-09-2024), ptjs1 (07-08-2024)
Old 07-08-2024, 01:55 PM
sanchez's Avatar
Just to make things a little clearer:.
Engine #2 came out of a Lucas ignition car. What I got was the bare bones 1990engine with a dropped valve.
Engine #1 is the engine that came out of the car. This was fully wired for the Marelli system, hence my questions regarding the parts exchange.
All of the pieces to make Engine #2 Marelli compliant will be taken off Engine #1.
The Marelli electrical harness is in the car.
As far as the engines go they are basically the same except for the "SA" "SB" designation.
Also I need some clarity on the flex plate. Greg said that all the V12 flex plates are the same. How does the rear sensor read the RPM. Does it count all the teeth on the ring gear or does it look for a particular tooth on the ring gear to calculate the RPM. I am curious.
Old 07-08-2024, 04:02 PM
ptjs1's Avatar
Paul
Greg,
That's intriguing! I looked through my docs but couldn't find a reference to the .0001 difference previously mentioned. Kirby's book mentions a "microscopic difference. I'll do some more digging and see if I can find what the specs and thresholds are for A & B size pistons and liners.
Paul
Old 07-08-2024, 05:38 PM
sanchez's Avatar
@ptjs1: After my last post, I was thinking that instead of going through all the work to remove the 'A" spec piston and liner to fit it into the "B" spec engine, wouldn't it be mor cost effective to purchase a "B" spec piston and re- ring all 12 pistons and new big end bearings(this was my plan all along). This way I do not have to get into liner removal/replacement issues. The liner with the damaged piston has no damage so I should just leave it be and get the "B" spec piston. I am going to clean of the piston crown and see what markings I find on the "B" spec engine.
PS: If the rings are the same for both the "A" and "B" spec pistons, the difference between the two must be minimal. Maybe the 0.0001 is the correct difference between the two.
Besides Kirby, I have seen this number in other posts by different people.
Old 07-08-2024, 06:03 PM
jal1234's Avatar
The first post in the thread below gives the math behind A spec vs. B spec. Worth a read.
https://www.jaguarforums.com/forum/x...rs-fyi-241438/
Jon
Greg in France (07-09-2024)
Old 07-09-2024, 12:57 AM
Sanchez
B spec (and A spec) new piston/liner sets are NLA. See post 1 in the link in post 13 above.
The rear sensor does indeed read the ring gear.
Old 07-09-2024, 01:07 AM
Originally Posted by ptjs1
Greg,
Paul
It is in the Jaguar XJS HE Repair operations supplement on page 04-01 under the subheading Cylinder block.
Grant Francis (07-09-2024), JJS- Florida (07-09-2024), ptjs1 (07-09-2024)
Old 07-09-2024, 08:36 AM
ptjs1's Avatar
Greg,
Rather embarrassingly, I find that I read and liked your post 3 1/2 years explaining the dimensions!
Paul
Old 07-09-2024, 08:53 AM
Mguar's Avatar
It really depends on you, but in the past I’ve put worn pistons and rings in a completely different block without regard to exact sizes. Yea I reused the rings. No I didn’t change the sleeves.
The rings took time to stop smoking oil. But eventually did. The first practice session she was smoking pretty good but at the end of that 20 minute session the rings settled in. A slight bit of oil smoke during the second session. But by the race it wasn’t smoking at all. (I used that engine in a race car). I even reused the bearings on the different crankshaft. Oil pressure was decent.
In the past, I’d always rehone the bores, measure clearances, replace rings and bearings. But I was fighting a deadline to get it ready for the next event.
I hate pulling head studs exposed to coolant. typically if the antifreeze wasn’t regularly changed the studs in the water chamber were too corroded to reuse. And I’d have to. Use heat to get them to release. Heat the block not the stud.
Old 07-09-2024, 09:16 AM
Greg,
Paul
Paul
Even more embarrassing, I had no recollection of writing it! AS we say in France "la veillesse est super, n'est-ce pas"
JJS- Florida (07-10-2024), ptjs1 (07-09-2024)
Old 07-09-2024, 11:49 AM
sanchez's Avatar
Speculation time is over. This morning I did the preliminaries to get to the connecting rod and as recommended I locked down the liner on the other side and removed the B1 piston from the engine. As mentioned by jal1234, the ring lands were damaged and there is a fracture on the piston running through the piston crown and the second compression ring land.
The piston is a B spec. The connecting rod bearing is good (babbitt is still intact and no signs of scoring). Even without removing the piston, I knew it was damaged. The liner is in perfect condition.
cylinder head
Liner is in good condition
this is what I used to lock down the liner on both sides
piston fracture in red circle
Top of piston
con rod bearing
I need a B spec piston PERIOD.
I read through all of the info Greg posted regarding the differences between the A spec and B spec pistons and liners and I do not want to put an A spec piston and liner with 11 other B spec pistons and liners because of the 0.0001 variance between the two. So, I am in the market for a used B spec piston. I have 12 good A spec pistons on the other engine.
In a quandary:
If I put an A spec piston and liner in, I will have a different CR relative to the other 11 cylinders.
If I put an A spec piston in a B spec liner I would have piston slap on that cylinder( as per Greg) Come on Greg. Are you ever going to use those 12 B spec pistons and liners during this century? Madame will be happy if you make some space for her LOL.
ON another note, I am going to post a wanted ad to see what's available out there. Maybe contact Mahle and see what's available.
Old 07-09-2024, 12:19 PM
ptjs1's Avatar
Sanchez,
There are others who are way more experienced than I am on re-building the V12. However it occurs to me that they key thing is just to make sure that each piston is matched to a corresponding liner. That seems much more important than worrying about whether the CR is exactly the same for all 12 cylinders. I THINK that I would be minded to put the best matched tolerance A-spec Piston and Liner of the ones you have, to replace that damaged B one.
I'm sure that others will have better opinions!
Paul
The following 3 users liked this post by ptjs1:
Greg in France (07-10-2024), JJS- Florida (07-10-2024), Mguar (07-21-2024)
Quick Reply: 1990 xjs engine parts swap "
