1990 XJS inside edge of front tires feathering
I'm over here from the XF and XJ sides. I'm working with a nice 90' XJS convertible with 50K original miles. Engine is very clean. Found a slight accumulation of oil on the front of the engine below the main pulley. I was working on some cosmetic issues when I found marked feathering on the inside edges of the front tires. More pronounced on the left-side. When I look at the car the suspension looks compressed. I don't know if its normal or the springs can't hold the car up any more. I would think there a serious toe-in problem. I asking the experts if there some suspension issues which may be the primary issue and not just an alignment problem. I was told the front end was recently redone. I would like any input from the experts. After lifting the hood this car scares me compared to my 04 XJ VDP and my 11' XF SC.
Feathering on the inside edge is, I believe, evidence of too much toe out. I think starting with an good quality alignment check is a sensible first step. If the front end was redone, then the new wishbone bushes and track rod ends should be obvious. If they are, there is a good chance the alignment post-rebuild was not done properly, or not done at all!
Greg
Greg
edobernig (09-23-2012)
Also, if suspension looks compressed you could have the wrong springs, e.g for a 3.6 or even for an early 4.2 sedan.
Oil leak: Most likely the front crankshaft seal being overdue for a replacement. It can be done in situ without removing the rad. I recommend protecting the rad with cardboard once the fan has been removed. The woodruff key on the crank has to come out to get the spacer out which is recommended because there is a track worn from the seal. Just put the spacer back the other way. OTOH with only 50k miles on the clock you may get away with replacing the seal only.
Thanks for the help
It will go to the Jag dealer for an alignment and Iwill let you know what they find. I suspect that when the front end was "redone" it was tie rods ends and not ball joints and bushings. The oil leak is also what I suspected. Its good to know you can change it with out removing the radiator. It is my understanding purging air out of the V-12 cooling system can be very difficult.
To remove the pulley to get at the seal, is that done from the top or under side while on a lift and do you need some type of puller?
BTW a key to purge the cooling system is to pour in coolant SLOOOOWLY
Front end alignment was the solution
The solution for the tire featuring was a front end alignment. Front end bushings were replaced and along with tie rod ends. It would appear the parts were replaced and the last shop did not send it out for an alignment.
Just going to leave the slight oil leak for now. Thank you for your help.
KarimPA
09-12-2015 08:15 AM
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
09-02-2015 11:43 AM
MC36
US Lower Atlantic
09-01-2015 07:34 PM
